Results 1 to 6 of 6
Reload Thread: i have a ?? for u
    HUDI's Avatar
    HUDI is offline Senior VIP Member
    Jan 2003
    aus
    44
    273
    36
    i have a ?? for u
    how do u get the smoth finish on out side of the box with the flow coat . the glass on the box is not extremly rough but it not super smotth . any idea ? any sugestion . would be appreaciated
    HUDI's Avatar
    Jan 2003
    aus
    44
    273
    36
    sorry this is fibre glass i try to coat with fiberglass try to coat with the flow coat
    Matador's Avatar
    Matador is offline -= StillBumping =-
    Oct 2002
    Ca
    2,093
    sorry didn't really get wat u asked. but u wanna smooth out the fiberglass or the plexyglass? well if it's for fiberglass, u can prob try to use a sander to smooth it out.
    Eclipse CD5444
    Momo MM6
    Arc Audio CXL-2100
    1 12'' RE HC
    Memphis MC-1000D
    www.angelfire.com/falcon/matador updated 5/02/03
    [email protected]
    taylor's Avatar
    taylor is offline THUNDER TUNES IS A FLAMER
    Jan 2002
    can
    34
    1,509
    bondo for smoothing
    ramos's Avatar
    Dec 2001
    Virginia
    52
    10,329
    104 Post(s)
    Here are 10 easy steps to get it smooth.
    1. sand
    2. sand
    3. sand
    4. sand
    5. sand
    6. Apply a little body filler to smooth out any pinholes.
    7. Sand
    8. check for pinholes, dips, rough spots
    9. apply more filler to fill anything you found in step number 8
    10. Sand some more
    5 % equipment
    90 % install
    5% beer
    80_Cutlass_mn's Avatar
    80_Cutlass_mn is offline What needs to be here?
    Nov 2002
    Anderson,Al
    32
    1,809
    If this is for Plexiglass then I think I heard that you could also sand it smooth. The procedure was something like take the highest grit sandpaper you can find like 1000 grit and wet sand the plexi. Then if you want it even smoother then you can take and gradually increase the grit as you sand. Then again a propane or oxy/acteylene torch can smooth it out to allthough with this method you have you be carefull and make sure you dont stay in one spot for too long or it will melt the plexi but eventually it will smooth it out very very nicely. The heat of the flame just barely touching the Plexi surface causes a very this layer on the top of the plexi to melt and run into any imperfections and such. Hope this helps as well
    Arctic White 1995 Camaro 3.4L
    Hifonics BX2005D- 12" IA Death Penalty
    Premier prs-x220 - MB Quart DSD213 components
    Pioneer DEH-P7600MP - Scosche 4 Ga. wiring kit
    Aol Instant Messanger: CamaroMN1995
