Results 1 to 4 of 4
Reload Thread: Am I understanding this right?
    ryeguy's Avatar
    ryeguy is offline Junior Member
    Sep 2007
    Detroit, MI
    Ok, so I have a 12" kicker comp, here's the box design specs per the manual:
    Using this, it seems optimum box area is 2.25^3 ft.
    Using the thread, I would want to use a plan that says 2.25 @ xx, such as this one:
    2.25 @ 32
    Are there any other calculations to take into consideration, or should this design picture suit me just fine?
    Max_Power's Avatar
    Max_Power is offline ^ From a Hairdryer ^
    Dec 2006
    Toledo, Ohio
    2,130
    Re: Am I understanding this right?
    you need to take into consideration that your woofer will take up some of that room, so you may actually end up with only 2.15 ft^3 or something. you may need a bigger box if you need 2.25
    References: (Sold To) - Blackbonnie, Ridinhi, BigEM (Bought From) - 95BlackGA, jonnybusa, 2002XLT, IamDeMan, kasimo420, SPL140.2, sundownz
    MY REF PAGE
    Car: 1993 Ford Crown Vic LX
    HU: Panasonic CQ-C700U
    Speaker Amp: Audiopipe AP2002
    Sub Amp: Audiopipe AP18001
    Sub: 15" Kicker L7
    Box: 5.5 cu.ft. @ 35Hz w/ 68sq.in. of port
    Front Speakers: Alpine Type R 5x7
    Wiring: 1/0 Knu Wire, 4ga Stinger Wire, Knu Distribution Blocks, 1/0 Knu "Big Three", Fosgate RCAs
    Accesories: AudioControl Epicenter
    ryeguy's Avatar
    Sep 2007
    Detroit, MI
    Oh, ok. In the manual it also says 2.25 + port displacement. is that factored in these designs? Is the 2.25 one what I want? (well it would probably be like 2.35 according to what you said)
    Max_Power's Avatar
    Dec 2006
    Toledo, Ohio
    2,130
    yeah, that is displacement + port. this box should be fine for you. I doubt you'll notice any difference with only .03-.06 cu ft missing. I would say you should be good with this box.
    MY REF PAGE
    Sub: 15" Kicker L7
