Results 1 to 4 of 4
Reload Thread: Sealing a Qlogic box
    Scott95GSX's Avatar
    Scott95GSX is offline Junior Member
    Mar 2003
    San Jose, CA
    I bought a Qlogic box, the one with the QX-ring, for my perfect 10.1 The problem is that it's not sealed at all
    Anybody have any experience with these things or any advice on how to seal it? Is there some sort of glue or sealant I can put around the outside? I have it screwed down tight, but air still leaks out around the plastic ring.
    ramos's Avatar
    Dec 2001
    Virginia
    48
    10,311
    5 Post(s)
    hear is a couple of ideas.
    1. Go down to your local hardware store and get some weatherstripping foam. Then run the weather stripping foam around the edge of the hole.
    2. lay a bead of silicon around the edge of the hole. Let it dry completely before installing the sub. Once the silicon is completely dry. Install the sub.
    5 % equipment
    90 % install
    5% beer
    azngurlbaybee's Avatar
    azngurlbaybee is offline Senior VIP Member
    Feb 2003
    No-Kali
    263
    Do you screw into the weatherstripping? Or around it?
    ramos's Avatar
    Dec 2001
    Virginia
    48
    10,311
    5 Post(s)
    Through it. All it is, is foam
    5 % equipment
    90 % install
    5% beer
