Results 1 to 8 of 8
Reload Thread: 10" Type-R box plans
    blackstar602's Avatar
    blackstar602 is offline Junior Member
    Aug 2007
    phx, az
    18
    can someone help me out by giving me some cut measurments for the factory ported specs? i would greatly appreciate it
    bdawson72's Avatar
    bdawson72 is offline Finally Has Bass Again
    Nov 2005
    434/804, Virginia 15's:Yezzir
    25
    17,568
    Re: 10" Type-R box plans
    Did you check out the sticky on box plans?
    149@32 hz(headrest)......Dammit i needs to be louder
    Aug 2007
    phx, az
    18
    i did but im not sure what i should be looking for... im a 100% noob on making enclosures so any help will be appreciated
    amartin_72's Avatar
    amartin_72 is offline Banned
    Nov 2005
    Madison , WI
    1,778
    dont make the factory box
    make it 2ft tuned to 35hz with 28 in port area.
    Aug 2007
    phx, az
    18
    so do i use the plans in the box plans thread labled 2 @ 35 #3?
    amartin_72's Avatar
    Nov 2005
    Madison , WI
    1,778
    yeah
    Skip01's Avatar
    Skip01 is offline Diggy
    Apr 2006
    Marrero,LA
    7,173
    1 Post(s)
    Id use this one:
    http://img62.imageshack.us/my.php?im...z24sqin6nl.png
    We had my next door neighbors 10R in a 1.8cu@28hz and it sounded soooo much louder than it was...metered at 137........but @32hz...got a vid ill post if ya want
    YOUTUBE VIDZ:
    http://www.youtube.com/user/Skip01
    Aug 2007
    phx, az
    18
    thanks for the input... really need it, ill tell you guys what i go with and post the build
