Results 1 to 6 of 6
Reload Thread: internal bracin
    Matador's Avatar
    Matador is offline -= StillBumping =-
    Oct 2002
    Ca
    2,093
    internal bracin
    i was designing my box for 2 12'' edks n ti came up to be
    W1 = 8'' W2=11'' L=31.5'' H=15.5''
    for a totla of 1.0634 cu feet before displacement, but i was reading n i would most likely need bracing inside. i'll be using separate chambers.
    would it help the "bracin" if i use 2 MDF pieces for the middle separator instead of just one? and how would you brace the inside? by connecting the 2 panels that connect (like in an L shaped side, u pur one like P, think of the L but with the block).
    n one last question, for more strength,
    [IMG]c:\wedgeHWWD.gif[/IMG]
    for the BACK PANEL of the box, let's say u put it laying on the ground, so for the 2 widths of the box, do u nail them on top of the back portion panel like
    or on the outer you nail the back portion onto the edges? like
    |__|
    remember, this is for strength purposes that i am asking. thanks a lot
    Eclipse CD5444
    Momo MM6
    Arc Audio CXL-2100
    1 12'' RE HC
    Memphis MC-1000D
    www.angelfire.com/falcon/matador updated 5/02/03
    [email protected]
    Matador's Avatar
    Oct 2002
    Ca
    2,093
    [IMG]C:\WINDOWS\Desktop\wedgeHWWD.gif[/IMG]
    Eclipse CD5444
    Momo MM6
    Arc Audio CXL-2100
    1 12'' RE HC
    Memphis MC-1000D
    [email protected]
    Matador's Avatar
    Oct 2002
    Ca
    2,093
    here's the link for the pic, guess didn't work
    http://www.mtxaudio.com/caraudio/edu...nstruction.cfm
    it's basically a box with a side slanted.
    Eclipse CD5444
    Momo MM6
    Arc Audio CXL-2100
    1 12'' RE HC
    Memphis MC-1000D
    [email protected]
    evo2k3's Avatar
    evo2k3 is offline Senior Bizznitch
    Dec 2002
    Chicago
    1,057
    dependant on the power your running that divider may be enough to stiften it suficiently....i think your going to be alright, genrally i always bace, but most the boxes i build are considerably bigger than that.
    I'm back to stock in my new car.....
    Matador's Avatar
    Oct 2002
    Ca
    2,093
    i will only be sending 400rms to each sub.
    can anyone answer this one tho
    think that you put the box facing up on the floor (sub openings on top) looking towards
    the back of the box thru the openings..
    |__|
    n with only this much power, do you think is needed to double panel the middle divider? put 2 panels instead of just one (3/4'' each panel)
    Eclipse CD5444
    Momo MM6
    Arc Audio CXL-2100
    1 12'' RE HC
    Memphis MC-1000D
    [email protected]
    evo2k3's Avatar
    Dec 2002
    Chicago
    1,057
    |__|
    it doesn't matter which way they go, both are acceptable, i hope your not nailing unless your usuing THIN brads to hold the glue? you should be fine with singl 3/4" mdf all around.
