I'm already on the final stages...
2 cubes @ 40hz (hopefully)... the port width from the rear of the box to the port wall is gonna be shorter than the port wall to the side of the box by 1/8" >_< ***** because I only noticed it after I glued it on. But whatever... I learned my lesson. I just need to figure out the remaining length of the port wall (plus end correction), glue it in, glue the top on and I'm done. If the end result doesn't fall apart, at least, I'll be satisfied.
One question I have though before I continue on... if the port bends 90 degrees after passing a corner of the box and then ends, would my end correction be .425 + .425 + .307, assuming 2 flanged ends and 1 free end, or should I just assume a total of .732?
Register To Reply
I poked a hole in the surround of one of my 8's... anyway, updated pics will be up on Friday of the completed box. Will let everyone know how it sounds!
Bookmarks
