It will be for a 12" TC-9 getting around 800w.
no.... it has absolutely no port.
bump
You may have some port noise with that. Try making the box a little shorter and going atleast 32 sq inches of port.
HU:Kenwood Excelon KDC-889
Speakers: CDT 61A's with rainbow x-overs
Front amp: Autotek MM100.4
Sub amp: (2) Audiopipe 1500's
Subwoofers: (4) 15" Crunch GPV
Box: 16 cubes tuned to 28hz (removable port)
Extra Batt: C&D 139AH
151.xx sealed up 154.xx in the kick
i cant make it shorter without making it smaller.... the dimensions i have are 15.5 x 17.5 x up to 26" Ill try making a bigger port though. **** with this the front width inside the box is 11.25" and the sub calls for 11.05 " internal cutout... thats cuttin it close. Also the basket diameter is 12.65" and i have 12.75" width to mount it on...
Will this work??
the widest you can go is 15.5 inches?!
well its going where the driverside rear seat in my truck used to be. It can be 17.5" wide 15.5" deep, and up to 26" tall... preferably around 22" tall. Its gonna be firing up... i guess i could make the width 17.5 and hte height 15.5 in those plans and have the port be on perpendicular to the rear seats....
Bookmarks
