Results 1 to 6 of 6
Reload Thread: TC OEM10 Sealed Box Ideas?
    dbaudio's Avatar
    dbaudio is offline Senior VIP Member
    Jun 2007
    NY
    435
    So, I just bought an OEM10 and I am looking to load it into a small sealed box. I've build enclosures before this one, but many were a shot in the dark that coincidentally worked. I want to build this enclosure the right way this time, with no guessing.
    Anyway, I was looking to build a sealed box with a rectangular shape, and then polyfill it because I would guess a rectangular box would be too big. I have taken a cube shaped box out of the picture as it would not go well with my CR-V's cargo area.
    I need a box that will fit under this cover:
    I was thinking of using Baltic Birch instead of MDF and bracing the insides as well as mounting the driver on a double baffle. But I just need to figure out the dimensions. Would I subtract the cubic properties of the OEM10 from the variable cubic dimensions of the box? And then reach a solution upon trial and error?
    Any help is appreciated. Thanks in advance!
    Specs:
    - Qts 0.357
    - Qes 0.400
    - Qms 3.35
    - Fs 30Hz
    - Res 3.11 ohms
    - Ls 4.0 mH
    - Lp 6.26 mH
    - Rp 9.9 ohms
    - Dia 208mm
    - Vas 19.3 liters
    - Mms 224 grams
    - Cms 119 um/N
    - BL 18.35Tm
    - Spl 83.3dB
    Enclosure Recoomendations:
    - Small Sealed: 0.3 cubic feet
    - Large Sealed 0.6 cubic feet
    - Ported: 0.5-0.6 cubic feet with a single 10″ or 12″ PR
    Jan 2005
    North NJ
    26
    4,010
    1 Post(s)
    Re: TC OEM10 Sealed Box Ideas?
    where in ny u from
    REF's
    Quote Originally Posted by cotjones View Post
    to answer someones question earlier.... after 194dBs your car no longer puts out sound, it puts out earthquakes
    Current Setup:
    Nakamichi CD-300, Coustic XM-3, Clarion EQS746, Coustic 510-DR, RE RE 6.5" Comps, Powerbass XA-900D, TCON Custom Subwoofer, Ported 1.5 to 30Hz
    Future Setup:
    In the works again
    WTB: Best Joke - Thread
    dbaudio's Avatar
    Jun 2007
    NY
    435
    Long island....you're from upstate right?
    Jan 2005
    North NJ
    26
    4,010
    1 Post(s)
    yeah. rochester/syracuse
    i would helped ya make one if u were close
    REF's
    Current Setup:
    Future Setup:
    In the works again
    dbaudio's Avatar
    Jun 2007
    NY
    435
    all my luck lol. At least I was lucky enough to get the sub I wanted. Otherwise, I wouldn't have to build a box...
    innsanes's Avatar
    innsanes is offline CarAudio.com Elite
    Sep 2006
    HB Cali
    1,316
    as long as the sealed box is sealed tight you cant really go wrong. Try going something like 10" high 14" wide and 10" deep. should get about .45 cf after displacement
    RSX
    ACTIVE CDT ES-630 comps
    Phoenix Gold 100.4
    Sundown 1500D
    0/1 gauge setup
    Big 3
    12" IDMAX
    Active Alpine 7998
    Kinetik HC1400
