Results 1 to 3 of 3
Reload Thread: Attaching wood to plastic
    Flipx99's Avatar
    Flipx99 is offline Violator of Terms
    Aug 2005
    Building 100
    24,132
    390 Post(s)
    What is the best adhesive for attaching a wood ring to a plastic door panel. Currently, I am using fiberglass. I dissolved some matting in resin and used that. I am thinking this may not last very long. Is there anything I can do to strengthen after the fact (it has lasted about 2 mos)
    However, when mounting my tweeter, I am going to have the door panel sandwiched between one piece of 1/2 at an angle and a piece of 1/4" mdf. I am thinking of fastening the pieces via screws on the backside, but what adhesive would be best use? I like both chemical and mechanical bonds for maximum performance.
    Black cat, white cat...all that matters is that it catches mice. -Deng Xiaoing
    I do homework for money. I specialize in finance. PM me for estimates.
    If someone uses me as a reference, please contact me first.
    ngsm13's Avatar
    ngsm13 is offline BSEE
    Sep 2002
    Cincinnati, OH
    35,726
    20
    65 Post(s)
    Re: Attaching wood to plastic
    So, are you going to see the method? If not...
    I recommend using clear silicone, GE SiliconeI.
    Apply generously, tape in place with 2" painter's tape (make sure to clean panel with adhesive cleaner before taping).
    Let dry overnight... and it's REAL secure.
    nG
    http://crunktimes.com/ct/
    nG - BSEE
    Max_Power's Avatar
    Max_Power is offline ^ From a Hairdryer ^
    Dec 2006
    Toledo, Ohio
    2,130
    17 Post(s)
    References: (Sold To) - Blackbonnie, Ridinhi, BigEM (Bought From) - 95BlackGA, jonnybusa, 2002XLT, IamDeMan, kasimo420, SPL140.2, sundownz
    MY REF PAGE
    Car: 1993 Ford Crown Vic LX
    HU: Panasonic CQ-C700U
    Speaker Amp: Audiopipe AP2002
    Sub Amp: Audiopipe AP18001
    Sub: 15" Kicker L7
    Box: 5.5 cu.ft. @ 35Hz w/ 68sq.in. of port
    Front Speakers: Alpine Type R 5x7
    Wiring: 1/0 Knu Wire, 4ga Stinger Wire, Knu Distribution Blocks, 1/0 Knu "Big Three", Fosgate RCAs
    Accesories: AudioControl Epicenter
