Results 1 to 4 of 4
Reload Thread: 911 almost finished
    lilgator's Avatar
    lilgator is offline Member
    Mar 2005
    Derby City USA
    65
    911 almost finished
    box is built two identical chambers built together in one box each chamber is 24w x 30l x 17 high external dimentions. each chamber has a port of 5"wide by 23" long and 15.5" high with no bends "yet" I plan on tuning lower. This is for two re sx 15" and the calculations I have is approx 4.2 cubes @ 34hz before sub displacement.
    a local stereo shop said my port openings are too wide, but on the re box calculator it was the only way to get the numbers to come out right.... Is the 77sq of port a piece too much for re sx 15's
    PLEASE HELP ME!!!
    the box is not all the way put together so I have time to correct any miscalculation I may have made. all that is remaining is cut out sub holes and screw / glue the top on.
    I broke the bank on a all out SQL install on my weekend cruiser suv and I want it to be right.
    I can email pics to anyone that can help.... PLEEEZE
    mokedaddy's Avatar
    mokedaddy is offline professional idiot
    Apr 2005
    Siccmade house
    38
    4,902
    Re: 911 almost finished
    It may be a tad high for some peoples liking but I have found that in between 16-20 sq in of port per cubic feet works well for most of my applications. You are just a bit over 18 so for my taste you are about right on, but only you will be able to tell for sure.
    'a man without enemies, is a man without character'
    fwb_1234's Avatar
    fwb_1234 is offline CarAudio.com Elite
    Jan 2007
    Greenville, SC
    1,902
    you are ok. you might be tuned a tad high, and if you want to go lower either constrict the port area a little or make it longer.
    either will work.
    Refs: SeanDub, jblanford, 95BlackGA, Flipx99, BiaBia
    lilgator's Avatar
    Mar 2005
    Derby City USA
    65
    heres a pic it may work, and I will play around with the tuning if you guys dont think I've totally screwed up already.
    http://s188.photobucket.com/albums/z...t=CIMG1085.jpg
