Results 1 to 10 of 10
Reload Thread: 2 subs in 1 box, only powering 1 sub for now...
    c_hayhurst's Avatar
    c_hayhurst is offline Senior VIP Member
    Jun 2004
    Columbus, Ohio
    416
    I have a ported box with 2 subs that I will eventually be powering 1 amp each (if and when my amps ever get here ).
    In the meantime, could I put both subs in the box and power just one of them? Would this hurt the subs where one runs and the other doesn't?
    Good job, America, you just elected a Socialist to be the next president.
    "Sabrina, don't just stare at it, eat it!"
    Refs:
    Teamquakecelica (bought from), Kfra315 (sold to)
    hoss's Avatar
    hoss is offline imma genius. so **** it!
    Sep 2003
    inside icetee, while he is inside seths sister
    34
    13,810
    Re: 2 subs in 1 box, only powering 1 sub for now...
    just run them both. only running one of them will give you problems. not to say you cant do it, just that you might as well just power them both. you will get better results that way, and the output will be the same, if not better, with the one vs the other (assuming you wire them correctly)
    Blove1991's Avatar
    Blove1991 is offline CarAudio.com Elite
    Jan 2007
    North Carolina
    1,821
    12 Post(s)
    x2 Dont take any chances
    Refs: BMXbikes, Wragold, Tommyk, ThumpinTitan, NewAgeKing, BushJ311, l7runner, jco1385, Big Joker, SPY, xxxbasshead
    IonSQL's Avatar
    IonSQL is offline CarAudio.com Veteran
    Jan 2006
    Aviston, IL
    42
    4,216
    If the box has separated chambers, you'll be fine.
    If the subs share the same airspace, don't do it.
    hoss's Avatar
    Sep 2003
    34
    13,810
    ^that too. although im willing to bet its a single chamber.
    blackbonnie's Avatar
    blackbonnie is offline The Revolution
    Jan 2007
    Grand Rapids, MI
    10,146
    if its a single chamber box, do not do it. the pressure from the powered sub will damage your non-powered sub. but if it has seperate chambers i would still not do it. but thats me. i would rather wait and see what it all sounds like, then to have a muffled sound of just one.
    HU - Pioneer 800prs
    Mids - Peerless HDS nomex 6.5's
    Highs - Seas Prestige Alumi-domes
    Front Stage Amp - Sundown 100.4D
    Sub - SA-12
    Sub Amp - Saz-1000D
    Wire - Knukonceptz, Kicker Hyperflex
    Blackbonnie References/Feedback
    Qbenjamin's Avatar
    Qbenjamin is offline CarAudio.com Veteran
    Jan 2007
    Tampa
    3,517
    11 Post(s)
    You will be fine if the chambers are separated. I did it for almost a year with one of my Orions. I had no problems whatsoever when I hooked up my other sub even though it was already in the box.....
    Sold to Ref's: IonSQL; envengineer; BAD_MAYHEM; oxsign; dvrmstrng; corto; wong05tsx; mrdurden; dirtyg; Cheesemind; gladiator_jai; bumpincrv; nycking23; slikvik; Mr.Ronin_2U
    Traded with Ref's:: Spike_e; jnoel; Sundownz
    Stock H/U; AudioControl Lc6i; Alpine PDX-V9; Focal Components & Coaxials; JL W6v2; Ported Enclosure @ 32hz; Second Skin Damplifier Pro
    What sounds good to you, may sound like crap to me...
    helotaxi's Avatar
    helotaxi is offline Kilroy was Here
    Dec 2003
    South Central (New Mexico that is...)
    42
    8,933
    Quote Originally Posted by blackbonnie View Post
    Actually, you'd be more likely to damage the powered sub. You effectively have it in a box 2x as big as it should be. Power handling will be severely reduced and it will sound like crap.
    Artificial Intelligence is no match for Natural Stupidity.
    Never underestimate the power of stupid people in large numbers.
    Life's tough...it's even tougher when you're stupid.
  9. #9
    Trixter's Avatar
    Trixter is offline Keepin it Simple
    Apr 2002
    Colorado Springs, CO
    40
    2,609
    29
    2 Post(s)
    Quote Originally Posted by helotaxi View Post
    that's the route i was thinking...the non-powered sub will not be ruined, it will just act as a passive. but the double air space could ruin your powered one depending on the power your giving it.
    2006 Jeep Liberty
    Adire Audio 15" Brahma running off Cadence A7hc, Clarion hu, MB Quart 6.5s and 5.25s running off old school Punch 800a4
    146+db @ 38hz with 1200w and a single 15"
    Lv = [(14630000 x R^2) / (Fb^2 x Vb)] - 1.463R
    *Vb = vol. in cu"
    **R = sq.rt. A / Pi (for square/slot port)
  10. #10
    Rawr-DQ's Avatar
    Rawr-DQ is offline !!!!Vote Third Party!!!!
    Dec 2004
    Fort Myers, FL Posts:____________31,337,666,999
    30
    2,882
    I have had 4 subs in a box single chamber, 1 of them the wire disconnected, and the ***** was going crazy, atfirst I thought it was wired out of phase...but it was only disconnected.
    Anyway, single chamber, nope, can not do it. You'll probably hurt both subs
    Quote Originally Posted by kickerassman View Post
    i was thinking some thing like this..... get a reall fine but strong sharp cable like them tension cables tie it around your neck and tie it to something..... then get some supper supper supper glue and glue your hands to your head.when the glue dries jump of the building with the cable cutting your head off and you would have your head glued to your hands ...... some one would see that and be like wtf omg that dude ripped his head off ... he mst have been pisssed!!!
    My Current Build Log: (16 8" Sundown subwoofers)
    http://www.caraudio.com/forum/showthread.php?t=367352
