Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
Reload Thread: would this box design be bandpass or just a wierd sealed box
    h17250x's Avatar
    h17250x is offline Junior Member
    Mar 2007
    Duncan, OK
    29
    What i am trying to do is completely isolate my trunk from the rest of the car. My box will be 2 separate hatchback boxes 14.5" deep at the top and 19" deep at the bottom. Width is 17" and height is 14".
    The two boxes will face each other with the bigger opening of 9 inches between the top edges of the boxes pointing to where the factory 8 " sub used to be in the deck panel. I am going to plate the boxes together with more mdf to create a front chamber sort of on the front rear and bottom. like putting the smaller boxes in a bigger mounting box. The fourth side will be open to the top facing the deck lid.
    Here is where it gets strange. I was going to make a plate/port to fit up through the 8" opening in the deck lid to try to direct all the sound through. But the virtual front chamber volume would only be around .78 cu ft. That is way too small for a bandpass to work right so i am considering cutting the 8 inch hole to around a 10" square hole. Because i am concerned about attaching the plate to the deck lid i was thinking i could stop the top plate/port about 2 inches from the new opening and screw a frame made from angle iron to it and attach a boot from that to the new opening. Would i still just have a wierd sealed enclosure system or did i cross over into a useless bandpass setup?
    I am probably either crazy or just desperate but either way i just wanted some input about it before i broke out the plasma torch and went ape S**t
    The car is a 2007 dodge charger
    The speakers are 12" Kicker comp cvr's i have 4 but i think there is now way to get them all in there and get any output so i am just using two of them wired paralled (dual 4 ohm subs). I have tried everything i could think of .
    I am running them with an exile 1200.1 and wiring it to a 1 ohm load for the full 1200 watts
    Omarvelous's Avatar
    Omarvelous is offline CarAudio.com Elite
    Jan 2004
    Queens, NY
    34
    1,371
    Re: would this box design be bandpass or just a wierd sealed box
    pictures would REALLY help! lol
    NOW
    2007 Maxima SE
    -HU: Stock
    -Goodies: 15" MX + Orion 2500D = sexAYYY
    Quote Originally Posted by bimma85
    Guess Im an internet nobody , but guess what; Im a real life somebody .
    h17250x's Avatar
    Mar 2007
    Duncan, OK
    29
    i am stuck in africa right now and my car is in oklahoma so i am just brainstorming for ideas for when i get home. really all i want to know is would connecting the two sealed boxes and leaving a 10 inch opening on the top have a bandpass effect or would it still be able to work as a sealed enclosure
    PhatTonyDeMarco's Avatar
    PhatTonyDeMarco is offline C0CK,its whats for dinner
    May 2005
    West Palm Beach, FL
    7,729
    Worry about your life right now, beware of the Rebel Troops.
    Fuck car audio buddy, you're in Africa!
    h17250x's Avatar
    Mar 2007
    Duncan, OK
    29
    Maybe this would help explain it. I don't know if you remember the old Qlogic bandpass boxes that had a plexiglass front removable panel. It was one enclosure with the dividers angled backward and some space left in the middle around 10x10 inches to install or service the speakers. What i am wondering is if you were to take a box like that and pull off the plexiglass front and instead put a tunnel the same size on it through the decklid would that work.
    h17250x's Avatar
    Mar 2007
    Duncan, OK
    29
    i'm not in the military and i am bored out of my mind and am going home in a week but thanks for the concern
    Trixter's Avatar
    Trixter is offline Keepin it Simple
    Apr 2002
    Colorado Springs, CO
    40
    2,609
    29
    2 Post(s)
    if your actually willing to start hacking into the rear deck of that car, then why not just cut 2 holes in the rear deck and mount the subs there. make a box on the under side....
    2006 Jeep Liberty
    Adire Audio 15" Brahma running off Cadence A7hc, Clarion hu, MB Quart 6.5s and 5.25s running off old school Punch 800a4
    146+db @ 38hz with 1200w and a single 15"
    Lv = [(14630000 x R^2) / (Fb^2 x Vb)] - 1.463R
    *Vb = vol. in cu"
    **R = sq.rt. A / Pi (for square/slot port)
    bjboertje's Avatar
    bjboertje is offline Member
    Jan 2007
    Iowa
    135
    i think it would just be plain sealed.
    Alpine 9855
    Rainbow CMX 265 front stage
    Stock rear fill
    ^Sundown SAX 100.4
    refs: TC Sounds, PepsiFiend69, SplChoice-, kicker06, PBateman
  9. #9
    h17250x's Avatar
    Mar 2007
    Duncan, OK
    29
    believe me i thought about hacking the thing to pieces but if this works alright i still have two 12's left and i don't have the room to put all four on the rear deck. i am hoping that if this works then i can add the other 2 12's behind these 2 boxes and go through the same opening and make another opening into the cab through where the fold down armrest is. That would give me another 6X9 inch hole to feed the sound through. So i would have around 308 sq inches of cone area and 154 sq in of opening to let it out into the world using all 4 and 154 to 100 with 2. I wish that the numbers were a little closer to even using all 4 but we will see how it works. I know that that is all fuzzy logic but it kinda makes sense.
  10. #10
    Immacomputer's Avatar
    Immacomputer is offline Cloud disappear
    Sep 2006
    Ocala/Oviedo, FL
    34
    4,672
    12 Post(s)
    Is this what you're wanting to do?
    Video 1
    I may make you feel but I can't make you think.
    Your sperm's in the gutter -- your love's in the sink.
    Video 2
  11. #11
    h17250x's Avatar
    Mar 2007
    Duncan, OK
    29
    that is pretty much the idea except the speakers will be angled back away from each other and the opening at the top won't be across the whole depth of the box. just the middle 10 inches but that is a pretty cool program you got there
  12. #12
    Sep 2006
    Ocala/Oviedo, FL
    34
    4,672
    12 Post(s)
    It's free and easy to use; google sketchup.
    If the panel doesn't cover the entire width, then yes, it will work like a 4th order bandpass.
    Video 1
    Video 2
  13. #13
    h17250x's Avatar
    Mar 2007
    Duncan, OK
    29
    i guess that i can go my buddies stereo shop and hop on their box building program and plug in this box and see what the output would be using the open space between the sealed boxes as a front chamber with a 10 by 10 by 3 in port. i am still kinda thinking that it is just closed enough to put some back pressure on the subs but not like a bandpass completely because of the port opening. I think i will just build it and see what happens. hell it's only one more sheet of mdf. i have spent more time analyzing it than it would take to build it.
  14. #14
    BigOso's Avatar
    BigOso is offline Team Maxxsonics
    Jul 2005
    Las Vegas
    40
    1,203
    Its a compression bandpass. what your doing is basically trying to have 2 sealed boxes with the woofers face each other but with a openening in the middle of the two correct?
    2006 SPLMAX Bass Race Competitor of the Year
    2009 New car, New Year, New Attitude
    Refs: Renegadesrun, Wowimzz x2, Nomad40 x2, 88Vette, Mattmcss, mtdewelf, Fiery, Tirefryr, TypeR0149, danteBirosel, bamaboy, jblanford, na_rsx, Civic96Lx, mdillon, xplayazplayzonx, stupify, Derrick824, soundstreamer and more but I can not remember.
  15. #15
    h17250x's Avatar
    Mar 2007
    Duncan, OK
    29
    Yeah that is the idea. Is a compression bandpass a bad design or just not all that common. I am going to be gone for a while to work but keep leaving input about it and thank everyone for their thoughts on it. Check out my gallery. I was in the construction phase of putting all this stuff in my old pickup and this is all the stuff i am putting in my new charger if i can make it all fit.
