Results 1 to 4 of 4
Reload Thread: 10" RE SR Ported or sealed???
    SmokeTitan's Avatar
    SmokeTitan is offline Junior Member
    Apr 2007
    in the interweb
    I need two boxes to go under the back seats in my king cab titan. Was thinking of trying the RE SR's. I've used the RE calculator to build a box that should fit, I'm just not sure if it would sound as good as I think it would. It seems to be small at .74cuft tuned to 34 hz before sub displacement, AND using 1/2" mdf If that isn't going to work then I guess i'll stick to a sealed box. the amp gives a rated 780w RMS to 1 ohm. Opinions?
    SmokeTitan's Avatar
    Apr 2007
    in the interweb
    Re: 10" RE SR Ported or sealed???
    Anyone's educated opinion would be helpful. Just a simple "yeah that would sound ok", or "no that would sound like azz because..."
    bjfish11's Avatar
    bjfish11 is offline FisherCustoms.com
    Aug 2005
    Garden Plain, KS
    32
    4,920
    If you go sealed you should be ok. RE recommends .5-.75 per sub sealed.
    Authorized SSA Loaded Enclosure Dealer
    Blove1991's Avatar
    Blove1991 is offline Single Cabin
    Jan 2007
    North Carolina
    1,801
    1 Post(s)
    If you use 1/2 be sure to brace
    Daily: 94 POS Accord
    Project: 86 2dr Chevy Blazer
    Refs: BMXbikes, Wragold, Tommyk, ThumpinTitan, NewAgeKing, BushJ311, l7runner, jco1385, Big Joker, SPY, xxxbasshead
