Results 1 to 4 of 4
Reload Thread: Multi bandpass question Box and Freq
    osix's Avatar
    osix is offline Senior VIP Member
    Feb 2007
    Asia
    166
    OK i have alot of question in my Mind and would be greetful if anyone can help me with it .
    I want a FLAT box . Instead of the Classic Square looking Box .
    if i build a box 5 inch tall - 30 inch width . and 14 inch across .
    Fitting it with a small 8 inch woofer ( measuring 4.2 inch height )
    the top and bottom of the box would be extremely close to the surface of the bottom and surface of the woofer.
    would i get negative effect ?
    i am using fiber glass instead of the classic wood or MDF .
    would i need have alto of sound different ?
    my Tuning freq is at high as 60- 65 Hz
    and the result i got from is
    0db - 41.79 hz
    -3db - 37.79 hz
    Peak at 2db 50 hz
    and go down
    back to 0db at 91.53hz
    flat at 67-82 hz ( 0.6 db )
    [IMG][/IMG]
    i am not sure if this is a good result .
    is a simple sub .
    The box is .9 cuft
    rear chamber 0.4 and front chamber is 0.5
    front chamber refer to the chamber the woofer surface is facing right ?
    Rear chamber refer to the chamber the bottom end of the woofer is facing ?
    i am new sorry for the silly question but is better silly and not ask and keep assuming .
    Here is a idea of the box
    [IMG][/IMG]
    Here is also some Data of the Subwoofer - in case anyone can come up with a better idea or suggestion ..
    Qts 0.663
    Qms 3.87
    Qes 0.8
    Vas 1.010 Cuft
    Fs 36.6 hz
    Re 4 ohm
    rpfuror's Avatar
    rpfuror is offline sound envy
    Oct 2005
    MD
    701
    3 Post(s)
    Re: Multi bandpass question Box and Freq
    I am not coming anywhere close to the output that you are getting with the calculations. What program are you using?
    With a passband that you are talking about your gain with in the passband is is going to be to high (I get around 9 dB, 3 dB will be the highest that I would go to be safe)
    As far as the drivers placement, you want to have it at min the diameter of the magnets vent away from obstruction or you will have problems.
    **rpfuror_designs**
    ** Ask me about box design and construction **
    Build: bigmike8771, bama350z, nismos14, speedyg76, onnoff7, orioles26, Airman21
    Design: RFmustang, e22s, Platestacker45, lilgator, diminishedpower, hannibal05
    Buy/Sell: 00maxima, Flyhalf, CaliforniabOY5, angrytrucker78, shawnfleming, dre2390 , IM IN HERE, Spellman, LazyRider, mikescanlon, AZ-ss, BLD 25, x1le woofercooker, Twisted_0912
    80INCHES's Avatar
    80INCHES is offline EPICENTERGLUED 2 ME
    Jan 2005
    WESTCHESTER, NY
    37
    6,962
    5 Post(s)
    wow if u have 5inches to work with i would do a bandpass...wat i would do is a down firing sealed box....and have a 2inch gap from the floor to the box....thats as close as u going to get from a bandpass
    heres a pic of a box i built yrs ago with 2 mojo 12's
    this is a down firing sealed box
    80
    osix's Avatar
    Feb 2007
    Asia
    166
    pardon me i forget to say that the Subwoofer is only a 8 "
    i am using winisd
    What would you suggest for the smallest thinest flattest box i can build for the subwoofer .
    a front and rear chamber measurment would be nice .
