Results 1 to 7 of 7
Reload Thread: Slot Port
    actlsub's Avatar
    actlsub is offline Senior VIP Member
    Dec 2002
    New York
    348
    Icon32 Slot Port
    Have a JL12w6v2 in a sealed 1.25cf with a jbl 600.1 amp. What to make a ported box for a change to see the difference, from what i herd i think i will like it better. On the JL sight they have a suggestion for a box but it has a 1.5cf slot port design and does not say what it is tuned to. Is this a good idea to try this because it is to JL specs, or should i just make my own ported box with a round port design??
    qxcvxz
    evo2k3's Avatar
    evo2k3 is offline Senior Bizznitch
    Dec 2002
    Chicago
    1,057
    Re: Slot Port
    No stick with the slot....JL subs tend to sound better with slot ports. I think those specs get you tuned to 32hz or so....you can make your own design but keep the slot port and probably go bigger then 1.5 mabey 2-2.5 cubes
    98greenlude's Avatar
    98greenlude is offline Junior Member
    Jan 2003
    bumble*uck, pa
    no i would go with the slot port. its a little harder to build but u wont get port noise. i personally had a kove armaggodon in a slotted port enclosure and it sounded better then anything else ive heard for what it was and the power it was getting
    panasonic df800u (soon to be replaced)
    infinity reference 605c fronts
    earthquake 6x9 3 way rears
    usa-100 us amp (the good underrated one)
    2 12' Phoenix gold titanium dual 4
    bass mekanik PT-1100
    2- 1 farad lightning audio caps
    with PLATINUM buss bars (bling bling)
    actlsub's Avatar
    Dec 2002
    New York
    348
    Re: Re: Slot Port
    Yea i would like to go a little bigger than the 1.5, however wouldnt i need to change the slot port lenght and design from the 1.5cf box to keep the tuning the same??
    qxcvxz
    evo2k3's Avatar
    Dec 2002
    Chicago
    1,057
    yup....its all going to change you can probably stick with the same hieght and width of the port, but yes to retain the same tuning freq. you will have to change the length....figure out what you kind of volume your working with and either myself or Jmac (he is better at it) can help you will the port length....there is a calculator at
    http://www.carstereo.com/help2/Articles.cfm?id=31 however i do not know if anyone has confirmed that it works properly or not.
    actlsub's Avatar
    Dec 2002
    New York
    348
    yea i tried using that port length calculator but i had a little problem. Using the 1.5cf box that JL suggests the JLslot port dimensions are 1.5 by 12.5 which would give an area of 18.8inches^2. If i set the calculator tuned to 32 hz then the minimum area came out to be 28inches^2. A big difference. In order to get the area of the slot port down to the 18.8inches^2 of the JL box, i had to lower the tuning freq down to 21hz. Can this be right?? I never herd of a box tuned to that low. Im pretty sure im doin this correct.
    Here is the site for the JL box: http://www.jlaudio.com/subwoofers/pdfs/W6v2_DS.pdf
    qxcvxz
    evo2k3's Avatar
    Dec 2002
    Chicago
    1,057
    I dont know that port area works right or now, dont wory about it since jl already gave to the size they recomend (which varrys very little with volume)....the calculator at the bottom works...i verified it with the forumlas I have for volume.
