Results 1 to 10 of 10
Reload Thread: Will a single box be tuned differently according to what sub is installed???
    lebomb's Avatar
    lebomb is offline Son Of Thunder
    Mar 2005
    Saytown, TX
    47
    467
    For example: My JL12w1 sub would be tuned to 28hz per the websites box specs:
    Subwoofer Volume
    (net int.) External Dimensions
    (Width x Height x Depth) Slot Port Internal Dimensions
    (Slot Width x Slot Height x Slot Length) Port Extension
    Length (EL) Tune to:
    (Hz) F3
    (Hz)
    12W1v2-4 1.75 cu. ft. / 49.5 liters 19.75 in. x 16.0 in. x 17.0 in.
    502 mm x 406.5 mm x 432 mm 1.5 in x 14.5 in x 33.75 in.
    38 mm x 268 mm x 857 mm 14.5 in.
    368 mm 28.0 29.5
    .............my prefab Bass Slammer box is tuned to 38Hz, but the size of the box is almost identical to the JLaudio box, except my port is wider, yet not as long.
    ...............so would the tuning frequency be more towards what my JLW1 is optimized in??? Or is it still in a 38hz box.
    I really dont care, because it sound great and is powerful.....I was just curious how all this works.
    Thanks in advance.
    2004 Accord EX
    OEM Headunit w/ XM Radio
    6 Disk In-Dash Changer
    Stock Neodymium Speakers
    JL12w1.v2
    Alpine sub amp
    RF and Stinger Wires
    Son Of Thunder
    helotaxi's Avatar
    helotaxi is offline Kilroy was Here
    Dec 2003
    South Central (New Mexico that is...)
    37
    8,945
    Re: Will a single box be tuned differently according to what sub is installed???
    The box itself (volume, port area and port length) determines the tuning of a ported box. the sub only matters when figuring out how much the displacement of the motor and basket assembly of the sub affects the air volume in the box. That will be a nearly negligible difference with most comparable subs (much less than a tenth of a Hz).
    Artificial Intelligence is no match for Natural Stupidity.
    Never underestimate the power of stupid people in large numbers.
    Life's tough...it's even tougher when you're stupid.
    lebomb's Avatar
    Mar 2005
    Saytown, TX
    47
    467
    Quote Originally Posted by helotaxi View Post
    Thanks......thats the answer I was looking for.
    2004 Accord EX
    JL12w1.v2
    Alpine sub amp
    Son Of Thunder
    JohnBlayz142's Avatar
    JohnBlayz142 is offline CarAudio.com Elite
    Nov 2005
    Naples, FL
    861
    If you make your port smaller by putting some wood in there or perhaps a sponge, you can plug part of the port which will decrease the port area, lowering the tuning.
    I had a pre fab box and I plugged part of the port...it played noticably lower after doing that.
    lebomb's Avatar
    Mar 2005
    Saytown, TX
    47
    467
    Quote Originally Posted by JohnBlayz142 View Post
    Im happy with it like it is.....it goes real low. I dont know, but to me it sounds deeper than 38Hz.
    2004 Accord EX
    JL12w1.v2
    Alpine sub amp
    Son Of Thunder
    Immacomputer's Avatar
    Immacomputer is offline Cloud disappear
    Sep 2006
    Ocala/Oviedo, FL
    28
    4,646
    Quote Originally Posted by lebomb View Post
    Material below tuning will still be audible but output starts to decrease at that point.
    Also, low is very very subjective. I'm sure much of the stuff you consider low, I would not consider low.
    Video 1
    I may make you feel but I can't make you think.
    Your sperm's in the gutter -- your love's in the sink.
    Video 2
    lebomb's Avatar
    Mar 2005
    Saytown, TX
    47
    467
    Quote Originally Posted by Immacomputer View Post
    Maybe, maybe not........alot of rap and so forth doesnt go low to me.....I listen to alot of Jazz and some of those songs go LOW. Also, a few R&B cds I have go LOW.
    What is it you listen to that you consider low??
    2004 Accord EX
    JL12w1.v2
    Alpine sub amp
    Son Of Thunder
    Sep 2006
    Ocala/Oviedo, FL
    28
    4,646
    Many of the songs on the Pirates of the Carribean 2 soundtrack drop pretty low (I consider anything 25hz and below, low). Some of the stuff from Bass from the Krypt get low as well. No rap or jazz or R&B I have ever heard has dropped to what I consider low. Many raps songs get down to about 30hz and I consider that dropping but not really low frequency.
    Video 1
    Video 2
  9. #9
    rpfuror's Avatar
    rpfuror is offline sound envy
    Oct 2005
    MD
    686
    ditto, actually most rap/r&b are all around 36-38hz.. some people say thats low.
    **rpfuror_designs**
    ** Ask me about box design and construction **
    Build: bigmike8771, bama350z, nismos14, speedyg76, onnoff7, orioles26, Airman21
    Design: RFmustang, e22s, Platestacker45, lilgator, diminishedpower, hannibal05
    Buy/Sell: 00maxima, Flyhalf, CaliforniabOY5, angrytrucker78, shawnfleming, dre2390 , IM IN HERE, Spellman, LazyRider, mikescanlon, AZ-ss, BLD 25, x1le woofercooker, Twisted_0912
  10. #10
    lebomb's Avatar
    Mar 2005
    Saytown, TX
    47
    467
    Quote Originally Posted by rpfuror View Post
    Well, basically all I really listen to is R&B, Hip/Hop and Jazz, so if that sounds good and low to ME....well Im happy. Im not going to go out and search music I dont listen to or like to prove what LOW really should be......that doesnt make sense.
    Anyhow, thanks for the input guys!!!!
    2004 Accord EX
    JL12w1.v2
    Alpine sub amp
    Son Of Thunder
