Page 1 of 7 1 2 3 4 5 6 7 LastLast
Results 1 to 15 of 96
Reload Thread: Box Build ----Fiberglass & MDF
    dbornotdb's Avatar
    dbornotdb is offline Custom Fabricator
    May 2004
    Bradenton, FL
    1,491
    19
    I'll just start with all the pics and the captions with them.
    Just a copy and paste from another forum I have it posted on.
    The bitter after-taste of a poor quality job will last far longer than
    the sweetness of that cheap price!
    Calikid's Avatar
    Calikid is offline Stack That Paper
    Feb 2006
    Los Angeles
    6,921
    Re: Box Build ----Fiberglass & MDF
    is that forum fiberglassforums.com
    dbornotdb's Avatar
    May 2004
    Bradenton, FL
    1,491
    19
    It is in a 99 s10.
    Here are the back half of the box pics. This is the part that will be in the bed.
    dbornotdb's Avatar
    May 2004
    Bradenton, FL
    1,491
    19
    Quote Originally Posted by Calikid View Post
    It is.
    You familiar with the build?
    dbornotdb's Avatar
    May 2004
    Bradenton, FL
    1,491
    19
    Resined it for a waterproof finish.
    This is just the inside, the outside was done also.
    dbornotdb's Avatar
    May 2004
    Bradenton, FL
    1,491
    19
    A shot of the back wall looking through the blow-thru at the new back half of the box.
    Never mind the mess........will be cleaned before it is done.
    dbornotdb's Avatar
    May 2004
    Bradenton, FL
    1,491
    19
    The notch here is for the console...and some style points.
    And todays radius' are brought to us by this half used roll of tape.
    dbornotdb's Avatar
    May 2004
    Bradenton, FL
    1,491
    19
    Working the floor and that ugly step.
  9. #9
    dbornotdb's Avatar
    May 2004
    Bradenton, FL
    1,491
    19
    Throw some braces on it and test the box connector to the bed part of the box.
  10. #10
    dbornotdb's Avatar
    May 2004
    Bradenton, FL
    1,491
    19
    When I left off, I had the connector pieces sides built and test fitted.
    Well here are the pics of it all done with the mounting flanges built on each side so it can be connected.
  11. #11
    dbornotdb's Avatar
    May 2004
    Bradenton, FL
    1,491
    19
    The inside flange is where it will be bolted to the bed part of the box and the outer flange will attach it to the inside part of the box.
    Here is the test fit of it all done before I put Everglass on the seams to reinforce it.
  12. #12
    stuckinok's Avatar
    stuckinok is offline Sick My Duck
    Jun 2006
    Rio Rancho, NM
    5,259
    looking real good man iam a fan of your work on fiberglassforums.com
    Team High Desert Mobile Electronics ABQ, NM
  13. #13
    dbornotdb's Avatar
    May 2004
    Bradenton, FL
    1,491
    19
    I dislike the dowl method of setting up rings. I only use it if I can't use a 2x4.
    I get asked how to use a 2x4 like this and when I explain it, they get lost. Maybe these pics will help.
    I cut the 2x4 at the angle I want the ring to sit and attach them together with 1 screw in the center where the pivot was for the router.
  14. #14
    dbornotdb's Avatar
    May 2004
    Bradenton, FL
    1,491
    19
    Position the ring at the angle you want it and shoot some paint around the base of it.
    This will mark the position of the 2x4. You will trace this position next.
  15. #15
    dbornotdb's Avatar
    May 2004
    Bradenton, FL
    1,491
    19
    Quote Originally Posted by stuckinok View Post
    Thanks.
