Results 1 to 6 of 6
Reload Thread: How to check if sealed fully?
    naiku's Avatar
    naiku is offline Senior VIP Member
    Sep 2005
    Virginia
    230
    Icon32 How to check if sealed fully?
    I am pretty much finished putting my box together, just have to carpet it and its all done. But before I carpet it, I want to be sure that it is sealed completely.........
    Is there any way I can test this? I used screws, glue and caulk on all the joins of the box.
    Thanks
    Worlddre's Avatar
    Worlddre is offline Big Darkie
    Sep 2004
    Charlotte, NC
    33
    18,014
    1 Post(s)
    49 Post(s)
    Re: How to check if sealed fully?
    take a fan and hold along all edges while running your hand along the inside...if you feel air then its not seaed....if you caulked well its prob sealed though
    "humility in the face of overwhelming genius will obviously amount to hypocrisy"
    inapontiac's Avatar
    inapontiac is offline CarAudio.com Elite
    Dec 2006
    Richmond
    29
    1,522
    i normally take a leaf blower to the inside walls/corners before i put it in as a final check but u should be good.
    bdawson72's Avatar
    bdawson72 is offline Finally Has Bass Again
    Nov 2005
    434/804, Virginia 15's:Yezzir
    30
    17,561
    8 Post(s)
    Quote Originally Posted by Worlddre View Post
    x2
    [email protected] hz(headrest)......Dammit i needs to be louder
    naiku's Avatar
    Sep 2005
    Virginia
    230
    Great, thanks all. Will give the fan a try and hope for no leaks.
    oxsign's Avatar
    oxsign is offline No Affiliation
    Jan 2006
    Sanford, FL
    5,855
    6 Post(s)
    267 Post(s)
    Put some water in there, and swish it around. Look for the wet spots.
    J/K The fan idea works good as well as hooking up the subs (for fitment), and feel for leaks then to.
