Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
Reload Thread: small enclosure design. 8" sub.
    hellomota's Avatar
    hellomota is offline Banned
    Oct 2004
    Chicago burbs, IL
    330
    Hi I was looking for optimal ported enclosure design for 8" subwoofer. I could not find any in the sticky or very little on the web. If someone with a program would be kind enough to give me demensions of the boards, I would apreciate it and leave feedback. Also probably 1/2 mdf would work just as well and be a lot lighter as I assume. Thanks in advance, Greg.
    Pyro_By_Nature's Avatar
    Pyro_By_Nature is offline CarAudio.com Veteran
    Dec 2004
    Colorado
    27
    5,953
    5 Post(s)
    Re: small enclosure design. 8" sub.
    You need to list a lot more info.
    Herb is the healing of a nation, alcohol is the destruction. - Bob Marley
    2005 Subaru WRX
    1990 Honda CRX Si
    Refs.: NHustlar, t00p, Kenny Pollock, vitveet, defj., mendon99, trevor87, saltyreefguy, willster, Iammurph, Dimensions684, kungfoojesus, karleon, bonestock, highhorsepwr, digital_ripper04, scottie johnson, stevew007, slammed, joshs98runner, PBateman, Sakura, duece212, mtx11, dirtye30, queball, audioarsonal, KHARPS. Not including box designs.
    rpfuror's Avatar
    rpfuror is offline sound envy
    Oct 2005
    MD
    701
    3 Post(s)
    yes max dimensions please???
    **rpfuror_designs**
    ** Ask me about box design and construction **
    Build: bigmike8771, bama350z, nismos14, speedyg76, onnoff7, orioles26, Airman21
    Design: RFmustang, e22s, Platestacker45, lilgator, diminishedpower, hannibal05
    Buy/Sell: 00maxima, Flyhalf, CaliforniabOY5, angrytrucker78, shawnfleming, dre2390 , IM IN HERE, Spellman, LazyRider, mikescanlon, AZ-ss, BLD 25, x1le woofercooker, Twisted_0912
    PV Audio's Avatar
    PV Audio is offline The Vision of Sound
    May 2004
    Indy
    28
    19,655
    I can help you out if you PM me with more information. Can't really do anything with what you said
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    10,782
    6 Post(s)
    1266 Post(s)
    What sub??
    hellomota's Avatar
    Oct 2004
    Chicago burbs, IL
    330
    finally found something I liked. Box for this sub. Thanks. http://www.partsexpress.com/pdf/264-854.pdf
    also max demensions would be 1cu ft net internal.
    kickerlivinloud's Avatar
    kickerlivinloud is offline Banning survivor
    Feb 2004
    Finger Lakes, NY
    31
    3,280
    I have a box I'll be selling soon if your interested... [email protected] Its 42 long by 8 high, by 11 deep.
    Here's a pic of it, i'm in the process of painting it...
    Its not perfect, the port did not come out well but it is nothing that effects the performance..
    Jon
    PatFitz9's Avatar
    PatFitz9 is offline CarAudio.com Veteran
    Sep 2005
    Chicago
    34
    3,842
    14 Post(s)
    I usually don't post in threads like this, but i know that you're in the chicago burbs. I also have a single 8 box i can hook ya up with. .87 cubic feet, and i think 35hz tuning. it was for a dd 1008. PM me if you want it.
    refs...
    twoohfour, PRIVATEpastry, hellomota, DBfan187, etznova, iamamp3pimp, btnhfan, XylerB, Digital B, Showrides, Thunder9500, Termlab, fawd06, PepsiFiend69, bholtmeier, Megalomaniac, bjfish11, j3bus2k3, probmxstyle, brigante, massiveaudiocw, JoeHemi57, BigRed98Ram, inapontiac, CFaber, VarsityBumper, 3.5Max6spd, Geezerpoop, phatcat600, Pimpdaddyq, XaznKewLguyX, ABSOLUTEAUDIO, lslugz, mgbcs, TeZ, mazdakid, Reson8, LaserRed38
  9. #9
    SHiZNiLTi's Avatar
    SHiZNiLTi is offline CarAudio.com Elite
    Jun 2005
    Scottsdale, AZ
    1,195
    1 Post(s)
    Quote Originally Posted by kickerlivinloud View Post
    Jon
    Shinny black box's FTW, explain the paint and process your doing to paint it. If that's lacqueer spray paint you can wetsand it for the Ulimae Shine.
  10. #10
    Feb 2004
    Finger Lakes, NY
    31
    3,280
    Quote Originally Posted by SHiZNiLTi View Post
    It has 2 layers of gray primer (sprayed) and right now 4 layers of black glossy. I hit the box before paint with 60-100-120-150 grit paper. Then hit both layers of primer with 150 (highest I had at the time). First 2 layers of paint were hit with 150 and the 3rd was hit with 320 grit paper. I'm hoping to put around 6-7 layers of paint with increasing grit paper. 320 is the highest i could find at the moment. I was looking at your box and hoping to reach close to the same effect. I'm only using a rattle can so I doubt I will get as nice a finish as you. Thats pretty much all there is to it...
    Jon
  11. #11
    SHiZNiLTi's Avatar
    Jun 2005
    Scottsdale, AZ
    1,195
    1 Post(s)
    Jon
    Cool, sounds like a good plan, but alot of sanding between coats of paint. I also just used rattle can spray paint for my box too, but it was lacquer spray paint, not sure if it sands differently then the paint your using....
    I sanded my bare wood box with 80grit too then used a "polyethylene wood sanding primer" that I brushed on 3 coats thick. I sanded the primer with 150-200 then just sprayed on 4-5 coats of black lacquer (5 cans total over 2 days) without sanding between coats. After the paint cured for a few days I then wetsanded the entire box with 2000 grit to get this finish...
    Although I have read the way that your doing it by sanding in between coats is the right way, I just skipped doing this on my box because the paint felt soft to my touch and I didn't feel like sanding between coats was the right thing to do because I could feel it ball up under the sandpaper, which is why I waited till the end of my painting to wetsand.
    Hope this helps, good luck.
  12. #12
    Feb 2004
    Finger Lakes, NY
    31
    3,280
    Thanks for the help!!!! I've been meaning to PM you about how you got such the nice finish. I'll have to look for some wet sanding stuff and give it a try. I'll make a small work log when I try wet sanding, loaded with tons of pics
    Jon
  13. #13
    hellomota's Avatar
    Oct 2004
    Chicago burbs, IL
    330
    post more pics of that box. It looks amazing.
    Back to topic anyone wants to design a box for that tang bang for me? tuned to 35
  14. #14
    Kagymp5's Avatar
    Kagymp5 is offline Senior VIP Member
    Dec 2005
    Lombard IL
    234
    Im in the chigago burbs and could prolly design and build it for you.
    if she wants it that bad. hit it from the front, shove a broom handle up her ***, and shove your fist down her throat and yell "TAKE IT ALL *****!"
    Quote Originally Posted by jdawg View Post
    I find it funny how sometimes fat girls wear a pushup bra to squish their big fat tittys in your face then they take it off and their ******* a pointing straight down like cow udders
    Ref's: PepsiFiend69, matt_martin87, negativezeroz, dB Dom
  15. #15
    hellomota's Avatar
    Oct 2004
    Chicago burbs, IL
    330
    somebody, please?
