Results 1 to 11 of 11
Reload Thread: MDF plywood?
    jcuts7171's Avatar
    jcuts7171 is offline Junior Member
    Nov 2006
    louisiana
    MDF plywood?
    im getting ready to build my box and i got the all the supplies and the mdf plywood, its marked 4x8 x3/4'' thick...but i had measured it when i got home and it measures 5/8'' thick....is that 1/8" gonna make a difference...i see that you need to use 3/4"....what to do?..............thanks
    bjfish11's Avatar
    bjfish11 is offline FisherCustoms.com
    Aug 2005
    Garden Plain, KS
    27
    4,922
    Re: MDF plywood?
    Yea, Id take it back and get 3/4".
    Authorized SSA Loaded Enclosure Dealer
    Aug 2004
    Lubbock, TX
    27
    2,935
    Re: MDF plywood?
    if ur not gonna be running a HUGE setup, throw some extra bracing in there and a double baffle and u'll be fine.
    2006 Chevrolet Silverado - Crew Cab Z71
    Kicker ZX 750.1
    Four 8" RE RE's
    Bought from: Jamaica2G, Ayrton, Prowler573, netherland24, tRiGgEr, BassBEAST88, HCCAfan, HOAX_1
    Sold to: James Bang, dkguitarist, Scoobydoo, ~Magick_Man~, BigEM, lostsoul, sephiroth619, Skip01, squeak12, CELLERBR, bvr_j_0969, OneKrazyKeebler, negativezeroz
    Traded with: Apollyon, zachzchw, jmanpc
    eBay: pmk0024 - 100% positive
    tdawg30's Avatar
    tdawg30 is offline Senior VIP Member
    Dec 2006
    Bowling Green, OH
    25
    407
    Re: MDF plywood?
    might as well use the stuff. I mean its a pain in the *** to take it back and lug another one home. just use some bracing and make a good box and you will be good.
    jmanpc i've had some serious sander *** with that box, and made al of the edges perfectly flush. like if you ran your finger over it, you couldnt tell it was 2 pieces of wood
    references: ivanfbi, mike dressure, ridnclean
    kickerlivinloud's Avatar
    kickerlivinloud is offline Banning survivor
    Feb 2004
    Finger Lakes, NY
    26
    3,280
    Re: MDF plywood?
    Depends on the size of the box. Anything over 5 cubs I'd make sure you have 3/4 or at least some extra bracing..
    Jon
    DaBurner's Avatar
    DaBurner is offline Member
    Jan 2006
    Long Island, NY
    147
    Re: MDF plywood?
    the wood i just got from home depot was in the middle between 3/4 and 5/8, i kept it, just make sure you pre drill the holes before screwing it together or you'll definetly split it
    TheBaron929's Avatar
    TheBaron929 is offline RFJunky
    Dec 2006
    VA
    25
    352
    Re: MDF plywood?
    it may be 3/4" MDF...
    all wood loses size when it's fabricated
    for instance 2 x 4's are really about 1 3/4" x 3 3/4"
    my father owns a carpentry business....thats the only reason i know
    You should be fine w/ what you've got
    ultimate157's Avatar
    ultimate157 is offline Engineering Student
    Mar 2006
    Worcester, ma
    7,245
    Re: MDF plywood?
    Quote Originally Posted by TheBaron929 View Post
    2x4's mass produced are 1.5" x 3.5" The reason for this is its cheaper to produce smaller 2x4's that still do the job (holding the required amount of weight) and they can produce more from the source wood. The smaller 2x4's get away with it because building code has changed the required spacing of 2x4's from 18" center to center to 16" (I'm pretty sure about that ...)
    If you get 3/4" MDF it should be 3/4" thick. And it is. I just measured some I have in the garage.
    '98 Jeep Grand Cherokee
    Source: Pioneer 880 PRS *Active
    Tweeters: 1" CDT TW-25
    Midrange: 6.5" CDT CL-65
    Sub: 15" SSA Icon
    Box: 4.0 @ 32hz
    Amp: Soundstream Tarantula 2kW
    Feedback thread
  9. #9
    helotaxi's Avatar
    helotaxi is offline Kilroy was Here
    Dec 2003
    South Central (New Mexico that is...)
    37
    8,945
    Re: MDF plywood?
    Dimensional lumber is smaller than the nominal size. MDF should be the thickness that it is marked and slightly larger than 4'x8'. Sounds like you got a mismarked piece.
    Artificial Intelligence is no match for Natural Stupidity.
    Never underestimate the power of stupid people in large numbers.
    Life's tough...it's even tougher when you're stupid.
  10. #10
    lilmaniac2's Avatar
    lilmaniac2 is offline Ask Me about SI Mag V4!
    Jan 2006
    Somewhere, Else
    25
    15,948
    Re: MDF plywood?
    x2
    3/4 inch mdf is 3/4 .... it isnt fabricated its pressed
    its also 4'1" x 8'1"
    its always fun when i tell the guy at lowes that its actually 49 inches wide and he persists to argue with me until he measures it
  11. #11
    jcuts7171's Avatar
    Nov 2006
    louisiana
    Re: MDF plywood?
    thanks...im gonna go head and bring it back...and find the 3/4".....jus to be safe...its gonna be a 8 cu ft box divided in two chambers...4cu ft each....for 2 15"
