Results 1 to 9 of 9
Reload Thread: mdf
    67camaross's Avatar
    67camaross is offline Member
    Jan 2003
    NJ
    68
    mdf
    What does mdf stand for and what is the difference between mdf and particle board if there is a difference
    Spddracer's Avatar
    Spddracer is offline Sounds Goooooood
    Mar 2002
    Ohio
    50
    1,345
    15
    medium densisty fiberboard , MUch more dence/stronger than partical board
    1990 300ZX Stage IV Twin Turbo
    Pioneer Premier P940MP
    CDT HD 6.5" Comps
    JL 300/4 Active
    (2) PG Ti10d
    Directed 1100d
    "WORK HARD.....
    PEOPLE ON WELFARE DEPEND ON YOU"
    paikiah's Avatar
    paikiah is offline Wangaholic
    Nov 2002
    Seoul, Korea
    40
    7,770
    46
    1 Post(s)
    Then anyone using HDF??? does it go by any other name?
    Team Caraudio
    Sony C90, 210 EQ
    Seas 27TDF/C, RE XXX 6.5, custom xo (dyn 240GT sitting idle)
    RF 60.2 amp
    eD A15.22
    Soundstream picasso 1400.1D
    Bass drive-by's are uncool.
    paikiah's Avatar
    Nov 2002
    Seoul, Korea
    40
    7,770
    46
    1 Post(s)
    is HDF much harder to work with? or it's not really necessary?
    I would think that it would be downright heavy as hell...
    Team Caraudio
    Sony C90, 210 EQ
    RF 60.2 amp
    eD A15.22
    Spddracer's Avatar
    Mar 2002
    Ohio
    50
    1,345
    15
    Originally posted by Jmac
    MDF is basically made of hundreds of compressed sheets of wood.
    Particle board is made of thousands of compressed wood chips. Particle board is also known as LDF or Low Density Fibreboard. They're usually good for up to 250 watts.
    MDF is made from 100's of comppressed sheets of wood ?? Hmm I think jmac is wrong
    CDT HD 6.5" Comps
    JL 300/4 Active
    (2) PG Ti10d
    Directed 1100d
    "WORK HARD.....
    Spddracer's Avatar
    Mar 2002
    Ohio
    50
    1,345
    15
    MDF is a type of particle board -- it is made of wood particles glued together by synthetic resin, with a medium density - as opposed to hardboard. They are typically found in 4' x 8' sheets, with 3/4" thickness, and are commonly used in furniture and cabinetry.
    CDT HD 6.5" Comps
    JL 300/4 Active
    (2) PG Ti10d
    Directed 1100d
    "WORK HARD.....
    Spddracer's Avatar
    Mar 2002
    Ohio
    50
    1,345
    15
    You have time for discovery channel with over 4000 post ???
    CDT HD 6.5" Comps
    JL 300/4 Active
    (2) PG Ti10d
    Directed 1100d
    "WORK HARD.....
    Apr 2002
    phoenix, az
    41
    61
    HDF is also known as high density marine plyboard
    MDF is just as dense as particle board (MDO) as they are compressed to the same stress... but as mdf is much smoother and also particle board is main purpose in life (useless for much else other than subfloor) is for laminating... it is more coarse and provides a better surface and needs far less prep in laminate or thermofuse applications.
    mdf on the other hand is to smooth and requires a bit of scuffing
    oh... when u get good at building u will not use screws ... u merely dovetail your joints a bit of glue and you get a much more strong connection and u can say... "wow". and find that if your not a cabinet maker or something close... then u just spent a lot of time learning something that is totally USELESS to you
  9. #9
    paikiah's Avatar
    Nov 2002
    Seoul, Korea
    40
    7,770
    46
    1 Post(s)
    hahahha...but from all the box-building that I've done (only done 1, but did a lot of samples), I now plan to make my own bed and have a little system done up for my room under the bed...kekek..I know it might be a longshot, but I do like my GT3, and I do like a good sound system everywhere I go~
    Team Caraudio
    Sony C90, 210 EQ
    RF 60.2 amp
    eD A15.22
