Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 33
Reload Thread: is a 4" port enough for a 12" bm???
    ~Magick_Man~'s Avatar
    ~Magick_Man~ is offline CarAudio.com Veteran
    Apr 2005
    bedford,Tx
    27
    2,149
    Icon30 is a 4" port enough for a 12" bm???
    i am building a box tomorrow and it turns out i have the room to make it a ported box so i want to go that route.
    the box will house 2 12" si BM's
    there is no good area to place 2 ports next to each other so i am planning on seperateing the 2 subs and each chamber will have a 4" pvc port
    does this sound like it would work?
    i will have some pictures of what i am trying to do in a little while
    Thanks,
    ~Magick_Man~
    Eclipse CD7200MKii - Memphis "Big" Belle - AudioControl DQS/DDC
    HAT L1V2 Tweeters - Focal Utopia 7W2 Mids
    DIYMA R12 x 2
    References:
    CA.com: the cybe, loserpunk, mega1268, JAZN, Digital Mint, B_Campbell, Pickup1,
    ndnbolla, jiggy2dmax, Carchrism5, JNTAR, SWEET06CAMRY, NoLimit, Mikeyboc,
    10W3dodge96, Megalomaniac, Buffalohed, Bigbirney420, Chubby, Nbudros, JrVtecAccord, flipside1212
    Icix: hificarguy, 2ndgen, Scout62, Infinity, Jet-Xino, Qalien, Hessdawg, CMILLET60
    DIYMA: SQ_Baru, danssoslow, Minivanman, Cheesehead, Starboy869, JoeHemi57, LESS
    Apr 2005
    bedford,Tx
    27
    2,149
    Re: is a 4" port enough for a 12" bm???
    here is the basic idea i have right now.
    it might change a bit but that is pretty much it.
    so if i dont make 2 seperate chambers will the subs really utilize the area in the middle?
    Thanks,
    ~Magick_Man~
    DIYMA R12 x 2
    References:
    xluben's Avatar
    xluben is offline CarAudio.com Veteran
    Jun 2006
    Minneapolis, MN
    2,132
    you need double that port area.
    have fun trying to make it fit
    bdawson72's Avatar
    bdawson72 is offline Finally Has Bass Again
    Nov 2005
    434/804, Virginia 15's:Yezzir
    25
    17,568
    heh, that truck will be happy after you are done though
    149@32 hz(headrest)......Dammit i needs to be louder
    Apr 2005
    bedford,Tx
    27
    2,149
    Quote Originally Posted by xluben View Post
    i am using a port calculator and for 2 4" ports in a 2 cube box tuned to 34 it says they need to be 26.xx"
    is that each?
    if it is then that *****.
    because i can fit in up to 14" long ports.
    would i be better off with 2 3" instead of 1 4" ?
    ~Magick_Man~
    DIYMA R12 x 2
    References:
    10W3dodge96's Avatar
    10W3dodge96 is offline I LOVE BASS!!!
    Sep 2006
    tx
    537
    Quote Originally Posted by bdawson72 View Post
    Yeah that guy is going to be very happy.
    NoLimit's Avatar
    NoLimit is offline Toy Yoda
    Jul 2006
    Dallas, Texas
    1,298
    2000 Toyota Camry SE
    Alpine 9857
    Infinity References
    Protected by COMPUSTAR
    Bought From: Audio Junkies, ~Magick_Man~, MetalMaxima, trevor87, AngryTrucker74, sayWhat? , Fi Car Audio, TheCybe(Made me a vinyl, Mucho ****)
    Bought / Traded with: Sampson
    Sold to: Benilson09, KyleC
    Apr 2005
    bedford,Tx
    27
    2,149
    this should be a little better.
    25sq-in of port per driver
    ~Magick_Man~
    DIYMA R12 x 2
    References:
  9. #9
    Sep 2006
    tx
    537
    did yo use those port tubes on NoLimits box?
  10. #10
    Apr 2005
    bedford,Tx
    27
    2,149
    Quote Originally Posted by 10W3dodge96 View Post
    no i used a mdf slot port on his.
    i am trying to stay away from that on this box because i dont want to mess with angling the port like it is on your box.
    and i have a ton of 4" pvc pipe so i might as well use some of it.
    ~Magick_Man~
    DIYMA R12 x 2
    References:
  11. #11
    xluben's Avatar
    Jun 2006
    Minneapolis, MN
    2,132
    um, what's the volume of the box (after displacement) and how long are the ports?
    adding two ports like that (and keeping them the same length) is going to make the tuning A LOT higher (10hz +) possibly.
  12. #12
    PatFitz9's Avatar
    PatFitz9 is offline CarAudio.com Veteran
    Sep 2005
    Chicago
    29
    3,787
    yeah, thats probably not going to work... the port calc is EACH port, so adding more is just making your problem worse
    refs...
    twoohfour, PRIVATEpastry, hellomota, DBfan187, etznova, iamamp3pimp, btnhfan, XylerB, Digital B, Showrides, Thunder9500, Termlab, fawd06, PepsiFiend69, bholtmeier, Megalomaniac, bjfish11, j3bus2k3, probmxstyle, brigante, massiveaudiocw, JoeHemi57, BigRed98Ram, inapontiac, CFaber, VarsityBumper, 3.5Max6spd, Geezerpoop, phatcat600, Pimpdaddyq, XaznKewLguyX, ABSOLUTEAUDIO, lslugz, mgbcs, TeZ, mazdakid, Reson8, LaserRed38
  13. #13
    Apr 2005
    bedford,Tx
    27
    2,149
    i dont have the exact number yet but i have about 2.2ish per driver after the port is taken out.
    i was looking at a single 4" at 11.xx" long which would supposedly give me 34hz with a 2cube box
    now i am looking at 2 10.12" long with 2cubes after displacement which should give me ~36hz
    i will end up with as close to 2.0 per chamber after the port and sub is taken out.
    ~Magick_Man~
    DIYMA R12 x 2
    References:
  14. #14
    Apr 2005
    bedford,Tx
    27
    2,149
    Quote Originally Posted by PatFitz9 View Post
    yeah i figured that.
    i was using one at 11.xx long shooting for 34hz
    now i am using 2 at 10.12 (i think) shooting for 36hz
    ~Magick_Man~
    DIYMA R12 x 2
    References:
  15. #15
    Apr 2005
    bedford,Tx
    27
    2,149
    so i guess the real question is will 2 4" ports 10.14" long in a box 2.0 cubes after displacement give me a 36hz tuning?
    i am judging this off the port calculator from carstereo.com
    ~Magick_Man~
    DIYMA R12 x 2
    References:
