If i'm cutting a port for a 4" port what do most people use for material and do i cut the hole in my box that size or would it be bigger tho fit somthing in there with a 4" hole.
popularmaterials used is a PVC pipe...Originally posted by Grateful
there are mftrs who sell ports with flared ends to minimise air turbulence...
as for the actual cutout.. buy the port first and measure the exterior dimensions...PVC pipes aren't 1mm in thickness..
Team Caraudio
Sony C90, 210 EQ
Seas 27TDF/C, RE XXX 6.5, custom xo (dyn 240GT sitting idle)
RF 60.2 amp
eD A15.22
Soundstream picasso 1400.1D
Bass drive-by's are uncool.
If either way i'm going to buy one what would be better to get.And do they make ones that are 11" long if i didn't use pvc.
hmm, I don't think so...Originally posted by Grateful
in that case, you're better off buying a PVC pipe and just using the flared ends that can be purchased separately~
Team Caraudio
Sony C90, 210 EQ
RF 60.2 amp
eD A15.22
i dont think there is any way to connect the flares to the pvc....and I have not seen 4 inche flares either....just use pvc...paint it black to match the carpet.
why would he paint it black if his carpet was not black????
If his carpet was gray then he would paint it gray...you told him to paint it black...~misinformationgiver~ :p :p
Subs: 2x Mtx Thunder 6000 12's
Amp: 1x Kenwood Kac-629s 350w 2ch.
The Rest ill just list the brand..i dont know the model #'s
HU: Pioneer
Fronts: Alpine
Rears: Pioneer
Ride: Ex. Cab Ford Ranger
Brown. (yuck) Auto trans.
Ideas on truck to get 3 years from now? No Chevy!
T exas
C ross
C ountry
R acing
A ccociation
grrr....grow up...honestly
Bookmarks
