Results 1 to 2 of 2
Reload Thread: Need Help Designing Box for L7's or L5's
    james33440's Avatar
    james33440 is offline CarAudio.com Elite
    Oct 2002
    FL
    31
    1,875
    I am going to use my MMATS D300HC amp (~1800 watts @ 2-ohms). The maximum overall dimensions that I can use would be 41"L x 20"D x 16"H. I am considering the following setups, if you could help me out, I would greatly appreciate it - 4 Kicker 10L7's, 4 Kicker 10L5's, 3 Kicker 12L7's, or 2 Kicker 15L7's? I assume that either would be in a sealed box, but could someone help me on the box specs? I would also need someone to build me one if possible. Thanks. I look forward to hearing from all of you.
    2001 Altima System:
    Alpine CDA-9855 (3Way Mode)
    Kicker Resolution RS6 Components (Active Setup)
    CDT Tweeter Image Enhancement Kit
    3 Ascendant Audio Arsenal 12's (Sealed)
    Kicker KX650.4
    Kicker KX1200.1 @ 0.67-ohm
    My Video Thread
    My CarDomain Rides
    james33440's Avatar
    Oct 2002
    FL
    31
    1,875
    I guess I want to use those dimensions overall and maybe like a clamshell design or sort of like 2 "V's" stuck together if it would mean more cu ft per driver. I want SPL.
    2001 Altima System:
    Kicker KX650.4
    My Video Thread
    My CarDomain Rides
