Results 1 to 9 of 9
Reload Thread: Attn. All Box builders and Wisconsin Members
    Hintzyboy's Avatar
    Hintzyboy is offline Sparks mean its working!
    Feb 2006
    Baraboo, WI
    7,536
    38 Post(s)
    Hi all,
    First off, I need some box plans drawn up with cut sheet dimensions. Max exterior dimensions are 13" high, 5" Top Depth-11" Bottom Depth. I have 52" of outer length available, but that needs to include some clearance between the port and the cab wall (side-firing port) What is the most airspace I can get out of these dimensions if I want to tune to 30-35 hz? Box is being built for a Team-PSI built TC9, and I'd like to get around 25 sq.in. or port area. I will also be using 1/2" MDF for the back and bottom plates to give some extra clearance for the sub magnet.
    Second, I'll be starting a new build soon, and could use some help. If any Wisconsin members within a couple of hours of Wiscosnin Dells are interested, there will be plenty of free food, etc.
    If anyone is interested in either proposition, hit me up on this thread, through a PM, e-mail, or MSN messenger.
    e-mail and messenger address: [email protected]
    Thanks,
    Aaron
    Refs:
    CarAudio.com: SlickRick, CubanAffection, trevor87, BigBirney420, Apollyon, Dinty01, TeamPSI, QtrHorse (x2), 6spdcoupe, Siddle, Smokingachicken, MisterGrubbs, Fast1One, MiniVanMan(x2), Jntar, blackbonnie, tigerf117, kasimo420, blaze383, XaznKewLguyX, SRim23, RidnClean, Team H&K, djvi0lent, jeeper07, turboaudi
    DIYMA: snaimpally
    CA.com Feedback: http://www.caraudio.com/forum/showthread.php?t=327860
    Ebay Feedback http://feedback.ebay.com/ws/eBayISAPI.dll?ViewFeedback&userid=hintzyboy79
    Hintzyboy's Avatar
    Feb 2006
    Baraboo, WI
    7,536
    38 Post(s)
    Re: Attn. All Box builders and Wisconsin Members
    Anybody out there?
    Refs:
    DIYMA: snaimpally
    PV Audio's Avatar
    PV Audio is offline The Vision of Sound
    Apr 2004
    Indy
    29
    19,655
    I'd be glad to make you a design, but I won't be able to drive to wisconsin to help with the build.
    PM me if you're interested in a design.
    Hintzyboy's Avatar
    Feb 2006
    Baraboo, WI
    7,536
    38 Post(s)
    c'mon, it's only a 6 hour drive .
    anyway, ygpm
    Refs:
    DIYMA: snaimpally
    xluben's Avatar
    xluben is offline CarAudio.com Veteran
    Jun 2006
    Minneapolis, MN
    2,129
    is this for a regular cab s10?
    with those dimensions you can get about 2ft^3 internal volume before port and sub displacement.
    i just designed one for my buddie's s10, and i managed to get 1.85ft^3 tuned to 35Hz with 21in^2 of port.
    he had to make a notch for the center console, and lost a click, though.
    he's thinking about buying some 8's to get his leg room back.
    (hope he doesn't mind me linking):
    http://www.s10forum.com/forum/showthread.php?t=288934
    Hintzyboy's Avatar
    Feb 2006
    Baraboo, WI
    7,536
    38 Post(s)
    yup, reg. cab. No center console, just one sliding bench seat. The seat is already moved up as far as I will allow. I'm not willing to give up the comfort and safety just for a little extra sound.
    Refs:
    DIYMA: snaimpally
    Hintzyboy's Avatar
    Feb 2006
    Baraboo, WI
    7,536
    38 Post(s)
    If it helps. I can go up to the window like the box pictured in the s10forum thread, but I'd have to have a couple inch indent on the passenger side so I can mount my amps.
    I'd rather have the amps on top of the box though, so I can hide the wires easier.
    Refs:
    DIYMA: snaimpally
    Hintzyboy's Avatar
    Feb 2006
    Baraboo, WI
    7,536
    38 Post(s)
    Just an idea, what Airspace and tuning would this box get me?
    Outer Dims:
    48" L
    13" H
    5" Top Depth
    11" Bottom Depth
    4x6" Square-O port
    -1/2" MDF used for Back plate, Bottom Plate, and port sides. 3/4" MDF for the rest.
    Refs:
    DIYMA: snaimpally
  9. #9
    xluben's Avatar
    Jun 2006
    Minneapolis, MN
    2,129
    Quote Originally Posted by Hintzyboy View Post
    Outer Dims:
    48" L
    13" H
    5" Top Depth
    11" Bottom Depth
    4x6" Square-O port
    if you went with those dimensions you get 2ft^3 net internal.
    for his i did a 3"x7" port 21" long to get to 1.85ft^3 @ 35Hz
    if you go with a bigger port and want to tune that low your net volume will be lower.
