Results 1 to 5 of 5
Reload Thread: two ideas for new sub install
    darren700's Avatar
    darren700 is offline got bu/\/\p?
    Jun 2006
    Windsor, Ontario, Canada
    485
    ok, right now i have just some 6x9's and a deck in my 97 cavalier 2 door. i have a set of cdt hd-62/m6 components, and eventually i plan on putting a system back in. so far i plan to use a merlin md23 for the components.. for the bass im still on the drawing board, i was considering making two sepeate boxes at 2.2 cu ft each that are 15.5 x 16 x 28 deep and sliding them in next to eachother in the trunk with 2 12" subs facing into the cabin from the fold down seat opening.. will seal the trunk from the cabin by fiberglassing wood to the frame... i was thinking either doing that so i have 2.2 cu ft at 28 hz for each box. then posibly throwing in two mags or two fi q 12's (powered off 2500d or 20.1 or saz-1500D). does this sound like a good idea? i was also thinkin of using my whole trunk as an enclosure, just making a baffle at the fold down seat opening and sticking two 15's in there or one 18" and seal the whole trunk up, then somehow calculate the volume of the trunk and tune the ports accordingly... i really like this idea but i dunno how well it would work... your input is greatly appreciated.
    2009 GMC Sierra SLE Ext Cab
    Hu: Premier P690UB
    Front: CDT ES-6MO, DRT-26a, Upstage Tweeter, 560 Xover
    Amps: Audioque AQ2200 and US Amps MD23
    Sub: SSA Zcon 18 D2 (6.6cu ft @ 28hz)
    Wiring: 2 run Knuconcepts 1/0 ga w/ Big 3
    Elect: Singer 350a Alt.
    Batts: Stock and HC2400
    Volenti's Avatar
    Volenti is offline Senior VIP Member
    Feb 2006
    Australia
    271
    Re: two ideas for new sub install
    The boot isn't a good enough "box" for your second idea to work, your first approach with the dual 12'' enclosures is a far better option.
    darren700's Avatar
    Jun 2006
    485
    yea i knew thatd be a long shot.. ill probably just end up going with the dual 12's im just hoping that dual 12" mags or dual 12" q's with 2500watts will be louder than the 15" mag in 3.5cu ft @ 28hz firing to back of trunk with 1200watts was
    Hu: Premier P690UB
    Wowimzz's Avatar
    Wowimzz is offline CarAudio.com Elite
    Apr 2004
    Greenwood, In
    26
    1,240
    Quote Originally Posted by darren700 View Post
    Your second Idea is called an Infinite Baffle. The ID q's and ava's were good for these types of installs. Search for REQ, or gcadidas-not quite sure on the spelling of his name, but both of them have pictures in thier sigs of an infinite baffle setup. I dont think you typcially use ports with these setups, as your main goal for it to sound good is sealing the entire baffle around your trunk.
    FOR SALE!!! BUY IT ALL!
    http://s394.photobucket.com/albums/p...%20for%20sale/
    refs: jonny101abc-bought my AA poly mid set,
    andrewmoore13-Bought my xbox360 games
    DJ Nitrous 427-bought my HC
    sjobas-bought my orion 1200d
    Req-bought some various wire/accessories
    aim: ryancmacy06
    email, and paypal lil_macy06@yahoo.com
    Quote Originally Posted by AznRevlAzn
    when you die, it will be one less person to worry about
    darren700's Avatar
    Jun 2006
    485
    yes i know what infinate baffle is, i dont want that, i wanted to essentially use the whole trunk as a box and port through the rear deck
    Hu: Premier P690UB
