Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
Reload Thread: 12'' mag box plans
    lookitsjim23's Avatar
    lookitsjim23 is offline CarAudio.com Elite
    Dec 2004
    Chicago
    29
    1,124
    12'' mag box plans
    Height- 17 inches
    Length- 31 inches
    Wheel well width- 37 inches
    Width 52 inches
    can anyone make up some box plans for this? (unless you know something that will hit lower and louder)
    2 ft^3 tuned to 32 Hz
    http://stereointegrity.com/Magnum12.html
    i would appreciate it...
    Dec 2004
    Chicago
    29
    1,124
    Re: 12'' mag box plans
    anyone?
    Calikid's Avatar
    Calikid is offline Stack That Paper
    Feb 2006
    Los Angeles
    6,921
    19 Post(s)
    5 bucks??
    May 2004
    Dramaville
    19,653
    Dec 2004
    Chicago
    29
    1,124
    ^^ whats the difference in those 3 designs, i see the length/height differences but what would that do to the output/lows of it?
    GrnEydDvl's Avatar
    GrnEydDvl is offline Registered User
    May 2006
    parts unknown
    787
    14
    Quote Originally Posted by lookitsjim23 View Post
    Nothing. If the NET Volume, port area, and tuning are the same they should have very similar output and performance.
    2 cubes at 32hz is apparently a very solid DD design for the MAG.
    EDIT: just noticed that the top one has bit more port area than the others. All should work well as long as they fit into your space requirements.
    Dec 2004
    Chicago
    29
    1,124
    so basically all three of those will have the same output?
    is there any box with the same tuning that will hit lower and louder...if there is i would be willing to pay for design..but if thats the best/perfect then those are great too
    May 2004
    Dramaville
    19,653
    The widest one looked a little wide to fit in your wheel wells. If it will fit it would be the best design. You wont really find a box that is lower and louder without major testing in your vehicle.
    See is the one with the 3" port will fit your specs, let me know if I need to tweek it a bit.
    -J
  9. #9
    Chevyaudio's Avatar
    Chevyaudio is offline :poof:
    Mar 2005
    Back in the Dirty BR, Louisiana
    31
    13,157
    Jntar puts 18 pounds polyfill in his 1cu box...makes Mag go BOOOM LIKE SO!
  10. #10
    May 2004
    Dramaville
    19,653
    Quote Originally Posted by Chevyaudio View Post
    2lbs in 1.2 thank you very much. There is only about .7lbs in there now and I dont like the low end now
    Time to pack it back in there.
  11. #11
    Chevyaudio's Avatar
    Mar 2005
    31
    13,157
    Sounds good.
  12. #12
    Dec 2004
    Chicago
    29
    1,124
    Quote Originally Posted by jntar View Post
    -J
    everything about the 3'' ported box fits except the length...the absolute biggest on it is 38'' from side to side, so i just put 37 there...
    is there anyway to keep that same design witht the 3'' port and make the length a little bit longer (make the 13'' longer, then bring the 41'' down a little to 37''. ) would that be possible
  13. #13
    PatFitz9's Avatar
    PatFitz9 is offline CarAudio.com Veteran
    Sep 2005
    Chicago
    34
    3,842
    14 Post(s)
    i have a box that is about that size. if i sell my mag, you can pick it up for like 20 bux. i can get you exact dimensions if you're interested.
    refs...
    twoohfour, PRIVATEpastry, hellomota, DBfan187, etznova, iamamp3pimp, btnhfan, XylerB, Digital B, Showrides, Thunder9500, Termlab, fawd06, PepsiFiend69, bholtmeier, Megalomaniac, bjfish11, j3bus2k3, probmxstyle, brigante, massiveaudiocw, JoeHemi57, BigRed98Ram, inapontiac, CFaber, VarsityBumper, 3.5Max6spd, Geezerpoop, phatcat600, Pimpdaddyq, XaznKewLguyX, ABSOLUTEAUDIO, lslugz, mgbcs, TeZ, mazdakid, Reson8, LaserRed38
  14. #14
    GrnEydDvl's Avatar
    May 2006
    parts unknown
    787
    14
    Similar output. These all use the same basic design and simliar specs.
    There are boxes that will play louder. Flared round ports should get you a little louder. I am sure someone could design you a bandpass or horn that will be louder. But those boxes have tradeoffs as well as the benefits.
  15. #15
    May 2004
    Dramaville
    19,653
    I will see what I can do to that design above to get it to fit for you. I am leaving work in an hour.
