Results 1 to 14 of 14
Reload Thread: Fiberglassed for the first time today...
    Frankensuby's Avatar
    Frankensuby is offline I'm in Ur F0rumZ
    Aug 2006
    PA
    911
    Amateur stuff really. I couldn't go MDF with the way I designed it, so I went Fiberglass.
    Their is 4 layers of fully saturated Mat (fine woven automotive mat) and on the top, we layed a thick layer of resin (darker brown spots) to try to smooth it out a bit. I need more resin and then I'm putting 3 more layers on the bottom, 2 more on the top, and sanding down. After that, I'm going to fiberglass the inside seam of the Fiberglass section to ensure and inside and outside seal.
    The bottom was the part I was displeased with. I need to seal it because it is barely sealed, and also, it has flex whereas the top doesn't.
    Any opinions?
    ~Levi
    2006 Subaru Impreza 2.5i
    System Currently:Speaker Amp|Phoenix Gold Xenon 100.2 Sub Amp| Phoenix Gold Xenon 600.1 Deck| Pioneer DEH6800MP Frontstage| Alpine SPR-17LS "]Sub| Phoenix Gold Xenon 10"
    Refs from Buyers:
    Refs from sellers: Dre2390
    Calikid's Avatar
    Calikid is offline Stack That Paper
    Feb 2006
    Los Angeles
    6,919
    Re: Fiberglassed for the first time today...
    nice job
    Symon_say's Avatar
    Symon_say is offline You can't get me
    Sep 2005
    Dominican Republic
    679
    nice job, put some pics of the process if you have
    Car: 2005 Ford F150 FX5
    HU: JVC KW-AVX830 on its way
    Front Spk: Haven't decided yet...
    Front Spk Amp: Profile AP1040
    Sub: 2 10" Memphis Sclass
    Sub Amp: Audioque AQ1200D
    .::DuD3::.'s Avatar
    .::DuD3::. is offline EE in training
    Oct 2004
    Chesafreak, Va
    25
    4,530
    looks good post some more pics
    Designated "Fast and the Furious" quoter.
    Pioneer 880prs
    PG Rsd 6.5
    15" Fi SSD w/copper coil
    Alpine PDX-1.600
    Alpine PDX-2.150
    Knukonceptz 1/0
    NebBlackshirts's Avatar
    NebBlackshirts is offline Nebraska Cornhuskers FTW!
    Oct 2006
    921
    looks good man, thumbsup
    bdawson72's Avatar
    bdawson72 is offline Finally Has Bass Again
    Nov 2005
    434/804, Virginia 15's:Yezzir
    25
    17,561
    goodjob
    149@32 hz(headrest)......Dammit i needs to be louder
    boogeroby72's Avatar
    boogeroby72 is offline Member
    Nov 2006
    nc
    37
    looks good, glassing stuff isnt that hard just takes time. but looks like youve got the hang of it now.
    ramos's Avatar
    Dec 2001
    Virginia
    48
    10,302
    5 Post(s)
    Looks decent so far my man
    Did you use any mold fabric ? Or did you just put mat ? Mold fabric will give you a more curved /shaped surface to lay mat on , and save you an arse load of filler work
    5 % equipment
    90 % install
    5% beer
  9. #9
    DeViOuSoNe's Avatar
    DeViOuSoNe is offline What's a Subwoofer?
    Oct 2006
    MD
    2,129
    Looks good, Just one ? Wheres it going? Lol
    Ref's
    DBman150, Nvruckus, Iceteebone, Army-Killa, Sxkicker89, Hoxie 08, BLD125, Yunvme666, Verlander, Ace_800, Duke, FrostyLemonade, Nmbr1Spt, chithead81, Calikid ....PLus many more....
  10. #10
    joetama's Avatar
    joetama is offline The British Ear
    Nov 2005
    Cincinnati, Ohio
    27
    15,306
    Sand that puppy down and a coat or 5 or clear coat and some good paint it'll look killer.....
  11. #11
    Aug 2006
    PA
    911
    Hey, Thanks guys!
    Been busy, so haven't visited the site in a little bit. I just finished throwing 4 more layers on, and I'm letting it sit for the final cure.
    I also loaded the inside seam with some silicone II bathroom sealant to make sure the pressure doesn't push out of the sides.
    I'm not sure, but I'm thinking when I get some more money, I'm gonna buy a gallon of Resin, 20 yards of Mat, and a quart of Steel Gray Metallic (color of my car) and painting it up all nice. Then, I'll get 3 coats of Clear coat (automotive grade) and we'll be done
    Quote Originally Posted by DeViOuSoNe View Post
    It's fitting into the corner of my Impreza's Trunk. I tried to avoid the space consuming Square type enclosure for space reasons. Next time, It'll be all Fiberglass
    I'm throwing roughly 500 RMS into a 10" Phoenix Gold. I don't have many inbetween pics, but I'll see if I can find some for your guys
    ~Levi
    Refs from Buyers:
  12. #12
    jeepintn's Avatar
    jeepintn is offline CarAudio.com Veteran
    Jul 2006
    Greenbrier, TN
    3,420
    nice job man, should come out good, definitely better than my first glassing attempt
    anyone around nashville who needs an install done pm me
    REFERENCES:
    smd4life(x2), scottiej(x3), army killa(x2), mike yayo, showrides, livinlife, pimpedout97x, PILOT 04, krouchchocolate, bigoso, blados, iamamp3pimp, xxxruckaz, joelowrider, CLJ, pesteele, danm7890, CrEaTrE, seth350, saywhat?, pepsifiend69, xxxpower, jadon087, 9512ds, skitzafit, billabongcr, ddeitz, ryanm923, massiveaudiocw, karkrazee96, tuck05, aeon, dcole18, purposesoap, morgans432, path2spl, krisfnbz, hessdawg, haunther, el_chupo_,
  13. #13
    smd4life's Avatar
    smd4life is offline NOTHING ABOUT MEADE
    Feb 2006
    TN
    7,558
    Quote Originally Posted by jeepintn View Post
    indeed
    nG
    Quote Originally Posted by thevic24 View Post
    And with this.....I will use this as an excuse to drink another beer....
    __________________________________________________ __________________________________________________ ____________________________________________
    Ref's:memphissoul4u, scottiej(x3), bassaddictj, jeepinTN(x2), Blados,lincolnls(slc720052), ssbogger, stuckinok(x2), matrxx dude, BoostedPontiac, fintheman, dbornotdb, mr. tibbs, lakota, iceteebone, WantedIsHere(HypnoticCure), Cahm Rohn, Bring97, Brian Owens, snoopysnooper, sdsport92064, annarbor84, tv559, RetroAudioinc, FJF, 01 S 10, oddiofile, stupify
  14. #14
    Aug 2006
    PA
    911
    From Concept...
    To progress...
    And finishing stages...
    I think I have more pics on the camera, but I'm at work
    ~Levi
    P.S.- Ramos, I just stapled Mat as tight as I could to each side and saturated with Resin. It actually dripped onto the bottom It did sag a bit, but when I get the last of the Fiberglass, I'll grab some body filler and fill in to make it flat. I have 5 layers on the top (curved, so much stronger) and 8 on the sides (it was flatter.)
    Refs from Buyers:
