Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 39
Reload Thread: can someone design me a box for free?
    bvr_j_0969's Avatar
    bvr_j_0969 is offline Senior VIP Member
    Oct 2006
    kentucky
    172
    like the title says could someone design me a ported box for 6 re 8's tuned to 30 hz?
    its a truck wedge box i have all the deminsions i just cant find the port lengths
    52" long, 10" bottom depth, 5" top depth, 21" tall i think the gross volume is 3.4 cft.
    using 3 3" aero ports with flared ends. im not even sure i can get enough port volume with these ports for 6 ported?
    subs specs .35 cft per sub ported subs displacement is .07 per sub.
    i would like to use just 2 ports but not sure if i could get anywhere near the port volume i would need?
    bvr_j_0969's Avatar
    Oct 2006
    kentucky
    172
    Re: can someone design me a box for free?
    and i cant figure out the displacment for aero ports? if i could find the displacement of them i could figure the rest out
    Big Dee's Avatar
    Big Dee is offline CarAudio.com Elite
    Aug 2006
    Ohio
    557
    It's easy you just subtract the flares and then calculate the volume of a cylinder.
    bvr_j_0969's Avatar
    Oct 2006
    kentucky
    172
    Quote Originally Posted by Big Dee View Post
    but the flares take up displacement too? im trying to get this as acurate as possible, also i read in another thread searching, someone said the more ports the more spl?
    Big Dee's Avatar
    Aug 2006
    Ohio
    557
    The inner flare doesn't count I think?
    The outer flares would take up so little space I probably wouldn't even count them.
    As far as port area I would just worry about having enough so that you eliminate port noise.
    bvr_j_0969's Avatar
    Oct 2006
    kentucky
    172
    and im not sure on how much port area i would need for 6 re 8's also how much port area does 3 3" aero ports give me?
    Big Dee's Avatar
    Aug 2006
    Ohio
    557
    Quote Originally Posted by bvr_j_0969 View Post
    I'll model them in WinISD and see what kind of port velocity they make.
    Big Dee's Avatar
    Aug 2006
    Ohio
    557
    OK. I have them modeled, what frequency did you want it tuned to?
  9. #9
    Dec 2005
    Mt. Juliet, TN
    27
    1,488
    The flares count 1" more lengthwise than regular length per flare. I dunno if it would make a noticable difference if you did anything more than that.
    Quote Originally Posted by xploit2 View Post
    OneKrazyKeebler BEST AVATAR EVER!! OWWWWEEEEEEEEEEEEEE!
    Refs:
    so long ago, they dont effin count anymore, get over it
  10. #10
    bvr_j_0969's Avatar
    Oct 2006
    kentucky
    172
    30 hz
  11. #11
    Big Dee's Avatar
    Aug 2006
    Ohio
    557
    OK for a 30 Hz tune you would need 3 3" ports 25" long each. The inner volume would take up .307 square feet. Although someone might want to double check my math.
  12. #12
    bvr_j_0969's Avatar
    Oct 2006
    kentucky
    172
    according to every aero port calculator ive checked said somewhere between 19-20" port length but i dont know how accurate they are
  13. #13
    Big Dee's Avatar
    Aug 2006
    Ohio
    557
    Aeros don't make any difference compared to regular tubes, you just have to add an inch or so.
    I actually calculated it wrong, it should actually be about 28" for a NET volume of 2.1 cu ft.
    edit. I read your post wrong, I thought you said you have .35 for every driver.
    For your box they should be about 20-21", my bad.
  14. #14
    dleccord's Avatar
    dleccord is offline CarAudio.com Veteran
    Oct 2005
    Sacramento
    5,953
    why not use the one over at RE.com?
    REFS
    blackgeltabs, theCybe(2x), xplcitcustmz, mabel4life, bumpn_gt , PENER, BLD 25, j3bus2k3(3x) , PRIVATEpastry, guy022077(3x), alpine3612, 03tibgt, rocky 59, mattmcss, yotabeater,pepsican, iceteebone(2x), sfsloop @ mac. com, vincemarq, maldecido33, dalucifer, BassAddictJ, thakidgame, Scoobydoo, marcusb419er, nVRuckus, frkkevin, killahbean, CBFryman2, Zeuslicious(2x), bizzy07, expo5.0, dragonrage, 1loudsuv, nismos14, James Bang, mtlhead, Rsx_03, thaster, teamsubgopoof, CRAZYCORNUTS18, ggk, Colt9699(2x), thangalang, BloodStalker999, dwaynem, chaunb3400, volstitan908, blackbonnie, Fast1one, nineball, rbiele126, JayRich, Al_Capowned, runwitbass
  15. #15
    bvr_j_0969's Avatar
    Oct 2006
    kentucky
    172
    i havnt built the box yet but each driver needs .35 per sub plus .07 per sub for driver displacement
