Results 1 to 5 of 5
Reload Thread: Box for port wars...
    F150Matt's Avatar
    F150Matt is offline Senior VIP Member
    Jul 2002
    Walker, LA
    27
    471
    Ok...here's the deal. I am planning on doing USACi, but there are also a lot of whitlee comps here. In most of the whitlees you can stick the mic in the port if it is 8x8 or larger, or right at the port if it is any other dimensions. In WinISD Pro, you can get peak port velocity. Would a higher velocity mean more SPL in the port? I know it would probably mean more port noise, but this box would be specifically for a high number in port wars. Also, what are some factors into the SPL at the port? Would a bigger or smaller box make better for port wars? Keep in mind I wont be using this box at the USAC comps where I'll be competing on the dash. For USAC I'll be using about 8ft^3 tuned to about 50hz. I want to have 3 boxes, one for daily, one for port wars, and my comp box. Let me know please. Thanks.
    Matt Sibley
    Team S.P.E.A.D. Captain
    Team Kicker
    Team Maxxsonics
    USACi Pro Stock 5001+ World Record Holder
    evo2k3's Avatar
    evo2k3 is offline Senior Bizznitch
    Dec 2002
    Chicago
    1,057
    think about the sound of wind going over a mic...its not that loud, just annoying...higher port vel will not do that. make enough port area so vel is under 30m/s. and that tunning freq is pretty **** high, you sure you want it tunned there?
    F150Matt's Avatar
    Jul 2002
    Walker, LA
    27
    471
    The tuning frequency listed above is for a comps only box. I'm getting the box to make the peak output very close to my resonant frequency. I will have a separate box for daily driving.
    Matt Sibley
    Team Kicker
    Team Maxxsonics
    evo2k3's Avatar
    Dec 2002
    Chicago
    1,057
    i explain the port vel concept to you ok?
    F150Matt's Avatar
    Jul 2002
    Walker, LA
    27
    471
    Yea, thanks. I didn't know if it would effect things or not.
    Matt Sibley
    Team Kicker
    Team Maxxsonics
