Results 1 to 2 of 2
Reload Thread: Complicated Build, Rookie Builder, need some advice
    NJTStang11's Avatar
    NJTStang11 is offline CarAudio.com Elite
    Dec 2004
    Chicago, IL
    27
    1,802
    1 Post(s)
    Due to my 1993 Lexus ES300's completely sealed off trunk, I've decided something new to try that I found on another site.
    http://www.clublexus.com/forums/show...+subwoofer+box
    My rear deck is similar to that, but may require some cutting. My questions:
    #1-Do I simply build a 3/4 or 1/2 MDF the exact same size as rear deck and just place it underneath the sheet metal?
    #2-Will shaving off some of the metal in my deck be alright for the car?
    #3-Correct me if Im wrong, but do I build the top and then just build the box from the top down and then just put supports on the bottom to avoid too much strain on rear deck?
    #4-I tore some **** out from between my back seat and trunk, and got a small area around 12"h x 4"w where my armrest folds down. Can I maybe port the box and have the port firing into the armrest?
    Pretty much what I want is 2 10's firing off the rear deck directly into the car off the rear glass w/ a port at the point of the armrest. Is this possible? or should I stay sealed like I originally planned? How much hell am I getting myself and my box builder buddy into?
    Thanks for the help in advance, and sorry for the stupid questions, just really don't wanna screw anything up. And for the interested folks it'll be a pair of 10" CVX's off 800rms each
    systembumping's Avatar
    systembumping is offline Senior VIP Member
    Jun 2005
    Athens, GA
    337
    Re: Complicated Build, Rookie Builder, need some advice
    You really don't have to do that much to your Lex to get it loud, but if you want to good luck.
