Results 1 to 7 of 7
Reload Thread: why do people do this
    nick3470's Avatar
    nick3470 is offline Ballin' on a Budget
    Jul 2002
    Ames, IA
    686
    im pretty new to car audio so i have some questions
    what is the reason that people install subs backwards????
    does and ohm load actually affect how loud the sub is????
    are ported boxes louder or better than sealed boxes????
    evo2k3's Avatar
    evo2k3 is offline Senior Bizznitch
    Dec 2002
    Chicago
    1,057
    Re: why do people do this
    many people play around with them to see how they like the best.....since sub bass is very close to 360 degree coverage, you can hear it pretty much however you install....it is also often more convienient in many cases.
    not directly...ohm load (impredence) is resistance in the wire....in MOST cases amps are rated x watts @ 2 ohms.....when you go up to 4 ohms the amps output falls to x/2 watts, less power GENERALLY means less output, in theory the 2 ohm setup will be 2x as loud ( 3db increase) people note that there are exceptions, jl makes amps that have the same output between 1.5-4 ohms, in that case ohm load does not effect loudness.
    basicly your comparing spl (sound performance level) to sq (sound quality)....generally a ported box will have a louder response (again usually about 3 db's, 2x as loud) ...a sealed box is generally more versital, and better suited for a more diverse listener who wants more quality, not that a ported box cannot sound great.
    i used a lot of words like "generally", "usually"....these are all generalazations, and opinions, like everything in the car audio scene
    MikeofTulsa's Avatar
    MikeofTulsa is offline The one and Only!
    Feb 2002
    Tulsa, OK
    20,875
    36 Post(s)
    generally looks.....
    ohm load affects how much power an amp will put out so in a way yes.....
    ported are louder than sealed but sacrifice some sq....sealed have good sq but not as loud....
    evo2k3's Avatar
    Dec 2002
    Chicago
    1,057
    Re: Re: why do people do this
    looks like i hit "submit reply" first
    TheGrimReaperKD's Avatar
    TheGrimReaperKD is offline Twiztid Mothaf*cka
    Dec 2002
    Florida
    27
    1,556
    Is that avatar a picture of a baby...?
    AIM: TwiztidKennyD
    violator5spd's Avatar
    violator5spd is offline Post Wh0re Hunter
    Oct 2002
    Ohio
    27
    1,795
    yep
    - John (AIM - ViolatorJF)
    2000 Dodge Neon
    DEH-P9300, JBL BP600.1, eD15A.22 in 2.5^3ft sealed
    Feb 2002
    Tulsa, OK
    20,875
    36 Post(s)
