Results 1 to 2 of 2
Reload Thread: 3.5 cubes 30-32 hz.
    Exploder 97's Avatar
    Exploder 97 is offline Monte Carlo SS now!
    Jun 2004
    toledo
    1,562
    3.5 cubes 30-32 hz.
    http://img30.imageshack.us/my.php?im...425sqin5gq.png
    I looked up on the MOE LESTER box plans and after the 3.5 @ 32 hz the pictures dont show up.
    I need a box for 2 12's is the link i posted big enough to fit 2 12's...
    my monte carlo 2000 can fit 35 length 18 tall and as deep as i want... but if that box will work let me know. thanks yall
    xluben's Avatar
    xluben is offline CarAudio.com Veteran
    Jun 2006
    Minneapolis, MN
    2,132
    Re: 3.5 cubes 30-32 hz.
    here ya go:
    http://i107.photobucket.com/albums/m...z50sqin6lw.png
    with those dimensions you should be able to get quite a bit more net volume if you wanted:
    http://www.subwoofertools.com/forum/...&Vas=&Fs=&CE=0
    5ft^3 @ 32 Hz with quite a bit more port area and it's still less deep than the moe lester box.
    that could even be bigger than you need, though.
