Results 1 to 8 of 8
Reload Thread: Build a tri-box- any advice?-->
    d audio 450's Avatar
    d audio 450 is offline Registered User
    Nov 2002
    Pa Philly area
    33
    752
    I wanna put together a sealed box to hold 3 10" MTX 6000's
    i want to make each sub independently sealed as well...
    does anyone have any suggestions as to how i should build it, what out of, volume ect
    i somehow plan to incorporate plexiglass as well for lighting...
    any advice, info, or comments would be greatly appreciated
    thanks a ton
    -Pat
    Randy Savage's Avatar
    Oct 2002
    New York
    33
    21,120
    41 Post(s)
    I'd reccomend at least 1.0 cu ft/sub, and use 3/4" mdf...what amp you got pushin them?
    MikeofTulsa's Avatar
    MikeofTulsa is offline The one and Only!
    Feb 2002
    Tulsa, OK
    21,244
    1 Post(s)
    309 Post(s)
    Fiberglass???
    BigBoomer's Avatar
    BigBoomer is offline Aka: Sgt. Slam
    Oct 2002
    Maypearl, Tx
    715
    Originally posted by Goddyd4me
    Fiberglass???
    No, thats tooooooo hard
    Subs: 2x Mtx Thunder 6000 12's
    Amp: 1x Kenwood Kac-629s 350w 2ch.
    The Rest ill just list the brand..i dont know the model #'s
    HU: Pioneer
    Fronts: Alpine
    Rears: Pioneer
    Ride: Ex. Cab Ford Ranger
    Brown. (yuck ) Auto trans.
    Ideas on truck to get 3 years from now? No Chevy!
    T exas
    C ross
    C ountry
    R acing
    A ccociation
    Feb 2002
    Tulsa, OK
    21,244
    1 Post(s)
    309 Post(s)
    ehh....not really.....just more time consuming
    evo2k3's Avatar
    evo2k3 is offline Senior Bizznitch
    Dec 2002
    Chicago
    1,057
    just build each chamber within the subs specs....you need wood glue, drywall screws, silicon, and 3/4" mdf (you should be able to only use 1 sheet, but you might need 2....its cheap as hell anyways like 15-20$/sheet). a screwgun /drill with phillips bit, circular hand saw or tale saw/radial arm.....and you got a setup to build ia great enclosure.
    Nov 2002
    Pa Philly area
    33
    752
    sweet- thanks a ton
    anyone have any recommendations for what to use for dampening? i know there are alot of products specificlly manufactured for audio applications...but are there any that are notice-ably better or different?
    thanks alot
    -pat
    n2ma's Avatar
    n2ma is offline Senior VIP Member
    Nov 2001
    St.Louis MO
    271
    box
    I would not use wood glue. Wood glue is great for hard wood wich has pores and grain to bond each piece. I would use liquid nails, Or cheaper route is using sub floor adhesive. (same as liquid nails.) The liqiuid nails when dry makes a nice bond between the pieces. Subfloor adhesive is by nature ment to expand and contract and still keep hold. The intense pressure in your enclosure will hammer that wood glue hard. A large tube of sub floor adhesive is cheap enough, 2.38 at lowes for a 16" tube. Hope I could help.
