I need a design for an eclipse 10" woofer
Anybody interested in making me a design for an Eclipse SW8102DVC? I think it should be in a sealed box, woofer will be faced up and in the trunk of a mercedes 300ce. It might just be me but the manual lacks all specs I need to use a subwoofer calculator.
http://beta.puttysoft.com/images/s2k...pkr_manual.pdf
Also, would there be any advantage to levitate the box a little bit? You know since the bottom is usually flat against the surface, maybe les at each corner?
- You may not post new threads
- You may post replies
- You may post attachments
- You may edit your posts
Forum Rules
Bookmarks
