Results 1 to 10 of 10
Reload Thread: Request: Box plan 1 10" SX ported
    MeGrog2's Avatar
    MeGrog2 is offline Member
    Jul 2004
    Chicago, IL
    53
    Icon10 Request: Box plan 1 10" SX ported
    Hi, I need some box plans If possible. I tried my self using WinISD to no avail so I could use some help, im willing to compensate you for your time via paypal $5.
    Here are my max dimensions
    Height: 12"
    Width: 41.75"
    Depth: 12" (I can go bigger here if need be)
    Sub: 1 RE 10" SX which is gonna be given 1100w rms
    Im gonna go with RE recommended for the tuning freq which is 35Hz
    Hear are the TS specs
    Electrical Q Value -Qes: .29
    Mechanical Q Value -Qms: 4.3
    Total Speaker Q Value -Qts: .27
    Free Air Resonance -Fs: 30.7 Hz
    Equivalent Compliance -Vas: 21.8 liters
    One-Way, Linear Excursion -Xmax: 22 mm
    Efficiency - SPL 1W/1m: 85.2 dB SPL
    Effective Piston Area -Sd: 310 cm^2
    DC Resistance -Re: 1.9 ohm
    Nominal Impedance -Znom: Dual 2 ohm
    Thermal Power Handling -Pe: 1000 W
    Force Factor -Bl: 21
    Here is my idea for the box I would like to have the sub in the middle with two slot ports like so || O ||
    Thanks guys
    mobeious's Avatar
    mobeious is offline what does 0hz feel like?
    May 2004
    Bartow, FL
    4,837
    26
    Re: Request: Box plan 1 10" SX ported
    i can do it for you
    Alpine CDA-9833
    (2)sets Cresendo ccx65
    Box Engineer for
    mobeious's Avatar
    May 2004
    Bartow, FL
    4,837
    26
    Cannot make ports on both ends due to the port would be to small and cause air turbulance so you have to have (1) 2" port on on end of the box || O like that
    this box is 1.5cubes after all displacment @ 34hz
    internal dimmentions are 33.5 X 10.5 x 10.5
    external dimmentions are 35 x 12 x 12
    overall port length is 28.75"--- the .75 is front face of box
    here is your cut sheet
    front - 32.25" x 12"
    back - 35" x 12"
    top - 10.5" x 35"
    bottom - 10.5 x 35"
    side (non-port) 10.5" x 10.5"
    side (port) 10.5" x 11.25"
    port board (1) 10.5" x 8.25"
    port board (2) 10.5" x 16.25"
    Alpine CDA-9833
    Box Engineer for
    MeGrog2's Avatar
    Jul 2004
    Chicago, IL
    53
    I would like to put a beauty panel on the front and double baffle to have a flush woofer would that cause any problems with the tuning. And shouldn't both sides be the same size since the port is in the front. A picture would really help if possible
    xluben's Avatar
    xluben is offline CarAudio.com Veteran
    Jun 2006
    Minneapolis, MN
    2,129
    MeGrog2's Avatar
    Jul 2004
    Chicago, IL
    53
    A xluben is that site accurate I found it earlier but I haven't heard of anybody using it on this site, so I didn't know if I should trust it
    xluben's Avatar
    Jun 2006
    Minneapolis, MN
    2,129
    yeah, it's pretty good.
    -it properly accounts for port and driver displacement when calculating net volume
    -port length is pretty much spot on with winisd and other equations i've tried
    -it uses; no of drivers, size/shape of drivers, xmax, and box volume to calculate port area (so no port noise)
    the nice thing about the last feature, is that if you want more/less port area just change xmax.
    also, you sometimes have to play around with the numbers to get the boxes to turn out right. it likes to give labyrinth style ports as well as goofing up the picture with some large boxes and wide, short ports.
    most importantly you really shouldn't use it's "Option Two" make sure you know what box you want it in, and it will give you pretty good set of plans. if you let it decide what box is best it'll give some pretty goofy results.
    EDIT: well, i just tried "option two" with the specs for my drivers and it came out with a pretty decent box with the "SQL" setting: 4ft^3 @ 30Hz not too far off from ascendant's recommended 4@32
    even so, i've seen other drivers where it throws out crazy numbers when you use that option, so it's not recommended. you should know what you want before you start designing a box anyways.
    also, the maximally flat setting would give a good box for home use (but not car audio) and the compact box is often so small it makes the port super long, and the gross box volume doesn't end up being much smaller. a few more reasons to stay away from option two.
    iamamp3pimp's Avatar
    iamamp3pimp is offline Bass Heads Entertainment
    Nov 2003
    Tampa FL
    31
    13,103
    8 Post(s)
    it can be done...Squeezed it close,
    1:8.8 ratio.
    I would have liked a little more area, but 27 squares is nice for a 10
    ygpm
    www.BassHeadsENT.net for all your custom enclosure needs
    Offering build service and expertise in the Tampa area as well as enclosures shipped nationwide!
    Robin@BassHeadsENT.net
    Check this thread for all the build logs being posted.
    http://www.caraudio.com/forums/suppo...ks-thread.html
  9. #9
    vetkilr's Avatar
    vetkilr is offline CarAudio.com Veteran
    Mar 2006
    brandon,fl
    3,238
    get pimp to do it................
    142.6@50 TL legal at me first meet.......
    refs:Flakko,saywhat,mmata13(sold 1605D amp),nVRuckus(bought fuse blocks), dkguitarist(traded 2 amps),MikeyB(sold MD2),CBFryman2(sold MD2),gundecker (bought 20.1),Sakura (2 Trades),killahbean (bought DMX12),Loud3(Bought Fiberglass Kicks),tb2007(sold diamond amp),iamamp3pimp(bought box's 3 so far /sold 20.1/sold 2 L7s,ZX650.4),chillcat34433(bought 12"RF HX2), ultimate157(sold opti 2000D),bballrrt06(sold opti 2000D),GrnEydDvl(sold kx2500.1),BassAddictJ (sold kx2500.1),pwuthedon(bought Lanzar 4000D)
    lostsoul (5.25 mtx comps) Bad once I hooked them up.....................
  10. #10
    Nov 2003
    Tampa FL
    31
    13,103
    8 Post(s)
    lol already did.
    good looking out tho peymp
