Box help!
I've spent countless hours designing this box for a 15" K that will fit my application the way I need it to.It has about 3.7^ft of airspace after driver and port displacement.My problem is the port.I was going to use an Aero-Port but I dont have the room to do it on the box,so my next idea was the slot port which is what you see here(the red line).My question is will this be alright?I know the port is suppose to be on the same panel as the sub,but that is not an option here.Any ideas/advice will be greatly appreciated......thanks
anyway,the sub will be on an angled panel facing forward with the port on a flat panel facing up
cool......I hope anyway.......gonna build the box one day after x-mas.......then I'll just be waitin on the K.......
if u ever want to look away from the slot port idea, www.thezeb.com sells snake ports that have the same aero-port idea but it is like a bendi straw so u can put it in a tight spot and fine tune it.
thanks vette.......but my problem is I dont have enough box area to mount that 7.25" flare and I was gonna have to use 2 of them to get my tuning right
oh, i must not have understood. i was about half asleep then.
anywayz, just go with the slot port and u will be fine.
Originally posted by vettelovr1124 i was about half asleep then.
Happens to the best of us....
- You may not post new threads
- You may post replies
- You may post attachments
- You may edit your posts
Forum Rules
Bookmarks
