Results 1 to 5 of 5
Reload Thread: How to calculate volume in a box like this...
    Afboy143's Avatar
    Afboy143 is offline aka Bumpin Expo
    Nov 2002
    Tampa, Fl
    384
    How do i calculate volume that looks like this
    ___
    |_____\
    Because Im building a box for my s10 truck and i need to find out how to find the volume
    Thanks
    Curtis
    Afboy143's Avatar
    Nov 2002
    Tampa, Fl
    384
    **** it messed up but i tryed to create a box that goes behind the seat of a bench in a truck
    Savant's Avatar
    Savant is offline Duke of DOH!
    Dec 2002
    Colorado Springs, CO
    48
    1,347
    Re: How to calculate volume in a box like this...
    ___
    |_____\
    Thanks
    Curtis
    Basically, you draw a line down from the shortest part straight to the base.. that gives you a rectangle (easy enough to calc volume there).. Then, you have a triangle left.. the formula for the volume is (I believe) 1/2 x base x height x width.. basically, it's 1/2 of the comprable rectangle you would if you took 2 triangles and flipped one over and put them together to make the rectangle.. make sense?
    .___
    |.__|__\
    Hope that helps..
    nick3470's Avatar
    nick3470 is offline Ballin' on a Budget
    Jul 2002
    Ames, IA
    686
    you right on the formula for figuring the volume of the triangle
    geonn's Avatar
    geonn is offline oalright
    Jan 2002
    minden, MI
    32
    ya take the top measurement and the bottom add them say 8 and 12 that be 20 divide by 2 so you get 10 then muliply that by height and width. after gettin that number divide by 1728 to get the volume in cubic feet
