Results 1 to 7 of 7
Reload Thread: 12" ported enclosure help?
    innsanes's Avatar
    innsanes is offline CarAudio.com Elite
    Sep 2006
    HB Cali
    1,377
    14 Post(s)
    I just picked up a 12" diamond d9 and now i need to build a ported box for it. dunno if i should tune it to 28hz or 30hz? I will be using two 4 " port tube becasue slotted is too difficult especially when i dont have a table saw. will using two 4 in port tube eliminate any port NOISE? thanx
    innsanes's Avatar
    Sep 2006
    HB Cali
    1,377
    14 Post(s)
    Re: 12" ported enclosure help?
    bump with sum help
    xluben's Avatar
    xluben is offline CarAudio.com Veteran
    Jun 2006
    Minneapolis, MN
    2,129
    i think two 4" dia ports should be plenty, but have fun fitting them in the box!
    for a 2ft^3 box you'd need two 40" long, 4" dia ports to get a tuning of 28Hz!
    i think a slot port would be easier. if you are making the cuts for the outside of the box, why can't you do a few more for a port?
    this has the same port area as two 4" dia ports, and would fit in most trunks, while keeping a good portion of your cargo space free.
    http://www.subwoofertools.com/forum/...&Vas=&Fs=&CE=0
    innsanes's Avatar
    Sep 2006
    HB Cali
    1,377
    14 Post(s)
    wow your right that does look easy. most of the time i see slotted ports with alot of bends and folds creating a very complex cut for me. but that looks realy easy with just two more extra cuts. thanks
    xluben's Avatar
    Jun 2006
    Minneapolis, MN
    2,129
    no problem! good luck with your box. i hope it turns out well.
    innsanes's Avatar
    Sep 2006
    HB Cali
    1,377
    14 Post(s)
    is there a big difference from tuning 28hz vs. 30 hz?
    xluben's Avatar
    Jun 2006
    Minneapolis, MN
    2,129
    no, 30 will be fine.
