Results 1 to 9 of 9
Reload Thread: top of box isnt sitting even with edges...
    Jared530's Avatar
    Jared530 is offline Drop bombs
    May 2006
    Sacramento, Ca
    2,259
    Ok. I built a box for my 15" XXX and when i was done i put it in my trunk but it didnt fit. So i took off the top peice of MDF and took 2" off the top with a jig saw. My cutting wasnt the best so the top doesnt sit flush with the rest of the box. And if i try to sand it, i dont think it will come out how i want. Would this effect the purpose of my box? Did this juss screw up everything? should i just put caulking around the whole top and just put the top on and screw it so that theirs no uneven parts?
    Refs: Kevokrook77, Cheapo, Killahbean, Coolwazabi, ShinyChromes(SCAMMER), Jnoel, matrxx dude, ssackett, Josh #44(SCAMMER), tc3k101, matrxx dude
    prochobo's Avatar
    prochobo is offline Sedan Sleeper
    Mar 2006
    louisville, ky
    1,662
    Re: top of box isnt sitting even with edges...
    I'd use Gorilla Glue to fill in those gaps. It will not only fill in the gap, but also bond the wood together, not as strong as wood glue, but it's better than nothing.
    Jared530's Avatar
    May 2006
    Sacramento, Ca
    2,259
    So if i have wood glue use that instead of gorilla glue?
    Jared530's Avatar
    May 2006
    Sacramento, Ca
    2,259
    Do you think this would effect the box?
    mazdakid's Avatar
    mazdakid is online now CarAudio.com Veteran
    Oct 2004
    illnoise
    33
    11,378
    6 Post(s)
    1310 Post(s)
    its probably not gonna be as strong as a straight edge to edge, but im sure it will hold if you use gorilla glue and liquid nails
    nbro3232's Avatar
    nbro3232 is offline Member
    Jul 2006
    Tallahassee, FL
    133
    if you use a belt sander you can get it decently level
    Jared530's Avatar
    May 2006
    Sacramento, Ca
    2,259
    ok, ill give it a try, ill juss load the top edges with caulking.
    acold7dusta's Avatar
    acold7dusta is offline y they stealin my bucket?
    May 2006
    buffalo, NY
    1,940
    why not fill it up with wood filler?
    01 Acura CL
    Eclipse CD3200
    Rainbow SLC 265 Active
    Sundown: SAX-50.4D
    ..............SAE-1000D
    Diamond D6 10" d2 sub
    ...........-.80 cu. ft FG sealed
  9. #9
    vladd's Avatar
    vladd is offline CarAudio.com Elite
    Sep 2005
    Haysi, VA
    34
    734
    if it was me i'd just start over, i don't think you'll ever reach the kind of strength you'll need if the cuts are as bad as they sound.
    refs:bamaboy cd6551, jimj, lilmaniac2, Vektork39, bimma85, AllThingsEnd, guy022077,baseballer1100, Brad .H
