Results 1 to 4 of 4
Reload Thread: Box for two E15K's
    Gauntlet's Avatar
    Gauntlet is offline bulletproof
    Oct 2002
    Cleveland, Ohio
    32
    8,477
    32
    Box for two E15K's
    I'm getting 2 Elemental Design 15 K-series subs for christmas and am now looking into a box for them. This is my first box building experiment, so I have a few questions, bear with me.
    These are the dimension I have to work with. The box can be smaller than the #'s listed, but no bigger:
    Width: 37 inches
    Height 14.5 inches
    Depth: 30 inches
    I obviously cant build a standard box, as my 15's will be unable to fit with a height of only 14.5 inches. My plan is to build a box where the subs mount on the top of the box, and the magnet faces straight down. This is where I need your guys help
    First off, I want to make the box ported using a slot port or aeroports. On the Elemental website, they say recommended cubic feet for a 15 in ported applications is 2-4. So would a box for 2 15's need to be somewhere around 6 cubic feet? (6.5 cuft, since the subs take up .25 displacement each). If this is correct, I need dimensions that will fit into my application and come out to 6.5 cuft. This is what I came up with, someone tell me if its correct/wrong (accounts for width of 3/4" MDF as well):
    Width: 37 inches
    Height: 11.5 inches
    Depth: 28 inches
    Now onto the port. I'm not positive what frequency I want to tune it to - I was thinking somewhere around 25hz, but i'm not sure. I want to have as much SPL without the SQ suffering that much. Like 60% SPL and 40% SQ. Any recommendations on what frequency I should use? And how do I go about figuring out the dimensions for the slot port/aeroport, once I have the frequency I want to tune it to?
    And what are the pros and cons of using slot ports vs. aeroports?
    Thanks a lot!
    "The world is full of people who want nothing short of perfect,
    but settle for less, blinded by their quest for purpose."
    - Slug
    bowtiefan's Avatar
    bowtiefan is offline Senior VIP Member
    Sep 2002
    East TN
    39
    192
    with those dim. the box is gonna be 5.444^ft before displacement and using 3/4" MDF.As for the different port designs I dont have a clue.I'm gonna be puttin a e15kd4 in a 3.7^ft box and tune it to 30hz.According to WinISD this is the best mix of SQ and SPL.I will be using the round Aeroports myself.
    SasquatchBump's Avatar
    SasquatchBump is offline SQ is better
    Apr 2002
    Pendleton, Oregon
    29
    494
    I would use square ports because of the LACK of port noise and be sure that the subs will fit in the 11.5" and put the subs in seperate chambers and remember about the displacement!
    1994 Probe SE
    HU: Alpine 7893
    Front Stage: JL XR 6.5" CSI
    Rear: Who Cares....
    Speaker Amp: JBL 180.2
    Sub Amp: Avionixx 500m
    Sub: Elemental 12O.44 getting 500+ watts
    EQ: Audio Control
    80 Sq feet of deadener
    Gauntlet's Avatar
    Oct 2002
    Cleveland, Ohio
    32
    8,477
    32
    Just what i was lookin for, thanks a lot
    - Slug
