Results 1 to 5 of 5
Reload Thread: RF sub secure on box
    drpain714's Avatar
    drpain714 is offline Member
    Nov 2002
    San Jose, CA
    39
    hi i have 2 12" z's and a dual bandpass box. I have already secured 4 screws on each sub. I have heard rumors to also use glue to reinforce it... is it true? any help or suggestion are welcomed. Thanks.
    Dwayne
    violator5spd's Avatar
    violator5spd is offline Post Wh0re Hunter
    Oct 2002
    Ohio
    32
    1,795
    They have 8 screw holes, right? If that's the case, I would just add 4 more screws to each sub to make sure it's secure. You never wanna use real "glue", but sometimes with bigger subs you can use silicon while screwing it down to make sure you don't have any air leaks. In your case, I don't think you'll be running enough power to really worry about alot of leaking. Good luck
    - John (AIM - ViolatorJF)
    2000 Dodge Neon
    DEH-P9300, JBL BP600.1, eD15A.22 in 2.5^3ft sealed
    drpain714's Avatar
    Nov 2002
    San Jose, CA
    39
    aight thanks is weatherstripping costly?
    Dwayne
    Brock's Avatar
    Brock is offline SEXYTIME!! NIIICE!
    Aug 2002
    KENTUCKY WHAT!!!
    7,751
    shouldnt be that expensive
    paikiah's Avatar
    paikiah is offline Wangaholic
    Nov 2002
    Seoul, Korea
    40
    7,770
    46
    1 Post(s)
    Hmm, won't the silicone cause rust to the speaker brace? I know they SAY it's coated with a lot of stuff, but I accidentally dripped a wee-bit of silicone on mine and after trying to remove the hardened silicone, the paint came right off too... I dont' think it's cheap paint either..it was a rockford...
    And about weather-stripping...is that stuff about the same as those that cushions a PC mainboard and other PC peripherals? You kow, those black spongy things... I've got a LOT of those in the office, and from the pictures that I've seen, it looks pretty much the same...
    Team Caraudio
    Sony C90, 210 EQ
    Seas 27TDF/C, RE XXX 6.5, custom xo (dyn 240GT sitting idle)
    RF 60.2 amp
    eD A15.22
    Soundstream picasso 1400.1D
    Bass drive-by's are uncool.
