Results 1 to 5 of 5
Reload Thread: Building a slanted box
    Fender85's Avatar
    Fender85 is offline Member
    Oct 2002
    N. Wilkesboro, NC
    32
    41
    Ok, how do I measure this beast? I know you divide it up into a rectangle and a triangle and you add. But i forget how to measure areas of triangles and such. i want around 2 cuft, but I'm just not quite sure how to get there right now. Thanks for the help.
    Chris
    geonn's Avatar
    geonn is offline oalright
    Jan 2002
    minden, MI
    32
    (base1+base2) or the top and bottom most likly devided by 2 times the lenght times width so (b1+b2)/2 *H*L then you take that number and devide by 1728 to get yer volume in cubic feet
    Jearod's Avatar
    Jearod is offline Member
    Nov 2002
    Duncan, OK
    32
    33
    Hah, if you're talking about a slanted box like so, I believe you take from the top of the slant in a straight line to the bottom, and creat a second rectangle, like so:
    You then find the area of (1) then find the area of rectangle (2) and divide by two. Then simply add them together.
    I could be wrong, Geometry was quite a while back.
    ASDF12345's Avatar
    ASDF12345 is offline Senior VIP Member
    Nov 2002
    us
    260
    mykeys's Avatar
    mykeys is offline URABUS
    Nov 2001
    South Prairie, Wa.
    45
    1,057
    Geon you are correct.. GA yours is easier though.. The only problem with sites is that most of us work on the box designs when we are supposed to be doing other stuff so the equation is generally needed on the spot..Well at least for the people I know that are into building em.
    Mike
    Your friendly neighborhood subaru freak!
