Results 1 to 3 of 3
Reload Thread: AA Arsenal 10's and sealed box
    Phreaker's Avatar
    Phreaker is offline Senior VIP Member
    May 2006
    Tampa,fl
    401
    Well My girlfriend ordered two 10" Ascendant Audio Arsenals and I am going to build her a sealed box for her Kia Sportage so she has a little room in the back for when she goes shopping or we go camping.
    Hopefully the subs will be here by Friday,but I wouldl like to get the box built and out of the way.
    First and foremost does anyone know the Front Mount Displacement of a Ascendant Arsenal 10 is in ft^3 or a math formula to find the front mount displacement in ft^3?
    Second,what size sealed box do the Arsenal 10's really like?Ascendant Audio recommends 0.7ft^3 per Arsenal 10 but is that before or after the subwoofers mounting displacement?
    She will be using my old POS Profile CA600M wired for a 2 ohm load to produce 420w RMS if any of that helps.
    One last thing,I will be bilding one box to house the subwoofers in,should I give each sub it's own chamber or will the y be ok in a single chambered enclosure?
    My System So Far
    HU = Sony CDX-M630
    Front Stage = Stock 3.5"
    Rear Stage = None
    Subs = 2 Alpine Type R's
    Sub Amp = Power Acoustik A2400DB wired to 1 ohm
    Sub Box = 4ft^ ported at 35Hz
    1991 Dodge Stealth with stock 90amp alt. and no Big 3.
    Gets twice as loud as the olds cutlass cierra!
    SQBubble's Avatar
    SQBubble is offline CarAudio.com Elite
    Mar 2006
    MTL
    1,895
    10 Post(s)
    Re: AA Arsenal 10's and sealed box
    Quote Originally Posted by Phreaker
    first! u mean the woofer displacement? (motor and basket) its about 0.15cu.ft
    second, id say go with recommended for sealed... 0.7cu.ft after woofer's displacement. just make it about ~1cu.ft the whole INTERNAL volume(dont calculate w/MDF thickness) and u should be good
    power should be ok, but i think itll be starving for more since its in a sealed box, but should be good enough for a girl! loll...
    each sub its own chamber, its better, but make sure its exact same size the 2chambers
    good luck man
    SQBubble's Avatar
    Mar 2006
    MTL
    1,895
    10 Post(s)
    make it 12"x12"x12"
    thats exactly 1cu.ft
    so u have to get ...
    2x 13.5"x13.5"------------bottom&top
    2x 13.5"x12"---------sides
    2x 12"x12"-------front&back
    of 3/4" MDF sheets
