Results 1 to 9 of 9
Reload Thread: Would this work for a 15" sub?
    May 2006
    McLean, VA
    33
    I'm thinking about making my first sub box and i want to make a vented box. THe sub is a Rockford Fosgate RFR2215 (its a old sub, but there awesome, atleast to me... )..
    so here are the dimensions for the box...
    H: 16.8"
    W: 25.9" These are all internal measurments and using a 3/4 MDF...
    D:12"
    it will be roughly 3ft^3...
    the Port diameter is going to be 4" and the port length is 8".. and i want it tuned to 35 hz..
    will this work? and will this be reasonable... Rockford says that the range should be between 2.25 to 3 ft^3....
    if you guys have any recommandations or tips that would be greatly appreciated....
    forget to mention that this is going into a 2003 honda accord 4dr...
    neonrt's Avatar
    neonrt is offline What are you looking at?
    Jun 2006
    Canada
    33
    1,688
    Re: Would this work for a 15" sub?
    dont forget to take the sub diplacement, and port displacment into account, or you'll end up tuning higher than you want.
    DarkFox's Avatar
    DarkFox is offline CarAudio.com Elite
    Apr 2006
    Old Lyme, CT
    29
    634
    I would go with at least 2 4" ports on a 15, however it will change your port length for same tunning.
    Quote Originally Posted by heyman421
    If SPL is your main objective, get 10's or 12's instead.
    Current System
    Car: 2008 WRX
    HU: Pioneer AVIC-D3
    Fronts: Tweeters up top
    Infinity 2ohm 3-ways in the doors
    Rears: Infinity 2ohm 3-ways in the doors
    Mid/High amp: HiFonics Zeus ZXi 4406 @ 110 X 4 rms
    Subs: 2x 12" Kicker L7 D4s
    Sub Amp: HiFonics Brutus BXi 2006D @ 1ohm (2KW RMS)
    98 Mustang Work Log (pics)
    08 WRX Work Log(Pics)
    fanaticalmoose's Avatar
    fanaticalmoose is offline Member
    May 2006
    McLean, VA
    33
    Quote Originally Posted by neonrt
    totally forget about that... so i should make the box bigger so it takes the sub displacement and port displacement so hte internal volume would equal roughly 3 ft^3?
    May 2006
    McLean, VA
    33
    also i want to know how what would be the best material to use... i'm thinkin about MDF, should i use 3/4" or 1" thick?
    iamamp3pimp's Avatar
    iamamp3pimp is offline Bass Heads Entertainment
    Nov 2003
    Tampa FL
    31
    13,134
    8 Post(s)
    3/4 is fine
    MDF
    www.BassHeadsENT.net for all your custom enclosure needs
    Offering build service and expertise in the Tampa area as well as enclosures shipped nationwide!
    Robin@BassHeadsENT.net
    Check this thread for all the build logs being posted.
    http://www.caraudio.com/forums/suppo...ks-thread.html
    May 2006
    McLean, VA
    33
    with 3/4" MDF would i have to use supports or nething like that?
    Nov 2003
    Tampa FL
    31
    13,134
    8 Post(s)
    a little bracing will help you with flex, but nothing complicated is necessary.
  9. #9
    May 2006
    McLean, VA
    33
    where would hte bracing go... i'm a complete noob in this stuff... but i would rather make my own and get some experience instead of paying like 100+ for someone to make me a sub....
