Results 1 to 9 of 9
Reload Thread: Amp box...
    beachboy016's Avatar
    beachboy016 is offline Member
    Sep 2002
    Los Gatos, CA
    137
    Amp box...
    I am planning on building an amp box to put in the back of my jeep to hold a jbl 80/4 and 600/1. It will be a box with hinges and a top so it looks just like a carpeted box from the outside but when you open it up the subs are there. I have a few questions though. How much room does there need to be around the amp for it to ventilate and should I cut holes in the side to let it cool easier. Secondly, should I use MDF or does it not matter what kind of would I use? Also, do you guys think it would be better to just mount one of my amps on the box and the other under a seat or should i try this amp box idea.
    Alpine 7892
    JBL 80.4 Amp
    Type R 5.25 Comps
    Type R 5.25 Coaxials
    JBL 600/1 amp
    JL 12" W6 V2
    ss3079's Avatar
    ss3079 is offline Eh Dere Hi Dere Ho-ser
    Mar 2002
    Up North
    22,571
    Sounds like you are going about it the right way
    For ventalation, you can drill maybe like 20 holes(3/8" or something medium sized) in the 2 ends of the box, and mount a neon tube in both ends...that way, it provides ventalation and looks good at night.
    Look around on the internet for more ideas - if you are worried about ventalation, you can use 12 volt cooling fans...amp racks with cooling fans plans can be found here: http://www.eatel.net/~amptech/elecdisc/caraudio.htm ---->right hand side, scroll down to "amp racks".
    - Steve
    Moderator
    2007 Chrysler 300C
    2005 Chevrolet Silverado 2500HD Crew Cab
    Optima, Volant, Bully Dog, Corsa, Gibson, Powermaster, California Super Trucks, Fox Racing, Airaid
    Alpine 7998, Alpine HDA-5460, Arc Audio MEQ-30, (2) Adire Audio Shiva, Image Dynamics CD-2COMP, Image Dynamics CX64, (2) Image Dynamics ID8V.2, Arc Audio 2100CXL, Arc Audio 4150CXL, Arc Audio 1500D-R
    2006 Kawasaki Ninja ZX14
    Quote Originally Posted by DJGTSR
    I dont mean to be rude, but what is the highest level of education that you finished?
    Sep 2002
    Los Gatos, CA
    137
    For the cooling fan idea, if I had two amps in the box and on each end it had the 20 holes would I place one fan on each end with the air flow going only one direction (i.e. one pushing air into the box and one pulling it out. Would the holes allow the fan to **** in enough air? Do you think I really need fans? I like the lighting idea, I could just use a 12 inch tube right?
    Alpine 7892
    JBL 80.4 Amp
    Type R 5.25 Comps
    JBL 600/1 amp
    JL 12" W6 V2
    MikeofTulsa's Avatar
    MikeofTulsa is offline The one and Only!
    Feb 2002
    Tulsa, OK
    21,235
    1 Post(s)
    308 Post(s)
    yes..have the fans blowing the same direcetin..push/pull
    Sep 2002
    Los Gatos, CA
    137
    What if I made the amp box out of plexiglass. I would do a bottom sheet and then pretty much open sides and then a hinged top. Would this make it so fans are not neccessary?
    Alpine 7892
    JBL 80.4 Amp
    Type R 5.25 Comps
    JBL 600/1 amp
    JL 12" W6 V2
    Feb 2002
    Tulsa, OK
    21,235
    1 Post(s)
    308 Post(s)
    what do u mean by hinged top???? cause unless the heat can go somewhere its not going to do any good.....now if u are just going to leave out the sides and u have plenty of air moving in that area u shouldnt have any problems
    Brock's Avatar
    Brock is offline SEXYTIME!! NIIICE!
    Aug 2002
    KENTUCKY WHAT!!!
    7,751
    you could just flush mount the fans on either side of the box so they arent visible, and then drill more little holes with the space that is left. For an amp rack it doesnt really matter what material you use but I would just go with MDF cause it is pretty easy to work with.
    ss3079's Avatar
    Mar 2002
    Up North
    22,571
    Yep, every thing sounds good
    - Steve
    PS: Plexi or MDF, doesnt matter...plexi would look awsome, little harder to work with though.
    Moderator
    2007 Chrysler 300C
  9. #9
    paikiah's Avatar
    paikiah is offline Wangaholic
    Nov 2002
    Seoul, Korea
    40
    7,770
    46
    1 Post(s)
    I read on Rockford's manual that you'd need at least 3.3cm clearance without a fan...
    Team Caraudio
    Sony C90, 210 EQ
    Seas 27TDF/C, RE XXX 6.5, custom xo (dyn 240GT sitting idle)
    RF 60.2 amp
    eD A15.22
    Soundstream picasso 1400.1D
    Bass drive-by's are uncool.
