I'm mounting 3 10w6 jls on the front of a box made of 3/4" MDF and I was wondering what size screws I should use? Does it matter if they go through the MDF? Should I predrill the holes for the screws?
Personally I use bolts and t-nuts to secure the sub to the box.
Igitur qui desiderat pacem, praeparet bellum -- Vegetius
"I told her about my conversation three years ago with the political leader of Islamic Jihad in Gaza. "What's the difference between suicide, which the Koran condemns, and martyrdom?" I asked. "Suicide," he replied, "is done out of despair. But remember: most of our martyrs today were very successful in their earthly lives." In short, there was a future to live for--and they detonated it anyway."
Yes predrill. And I'm with heresy I use bolts and t nuts also.![]()
5 % equipment
90 % install
5% beer
How does that look with the bolts and the tnuts exposed? or do you hide them somehow?
You can't see the t-buts because they are underneath the face of the board where the subs sit and the bolts look no worse than screw heads if not completely the same.
3/4" - any size.Originally posted by Jon403
No.
Yes.
Bolts and t-nuts are the way to go![]()
- Steve
Moderator
2007 Chrysler 300C
2005 Chevrolet Silverado 2500HD Crew Cab
Optima, Volant, Bully Dog, Corsa, Gibson, Powermaster, California Super Trucks, Fox Racing, Airaid
Alpine 7998, Alpine HDA-5460, Arc Audio MEQ-30, (2) Adire Audio Shiva, Image Dynamics CD-2COMP, Image Dynamics CX64, (2) Image Dynamics ID8V.2, Arc Audio 2100CXL, Arc Audio 4150CXL, Arc Audio 1500D-R
2006 Kawasaki Ninja ZX14
Originally Posted by DJGTSR
Sorry I don't really understand the t-nut thing, its sounds like a great idea so could someone explain it to me. The bolt you use has little progs by the head right? And so do you have the head on the inside of the box with the nut on the outside? Any help is appreciated, pictures would be great also.
Alpine 7892
JBL 80.4 Amp
Type R 5.25 Comps
Type R 5.25 Coaxials
JBL 600/1 amp
JL 12" W6 V2
Nevermind I think i got it. Tell me if this is right. So it is a nut with prongs on it. And you get it stuck to the inside side of the mdf where the pre drilled hole is, then you can just thread the bolt through and tighten it down and this leads to easy installation and removal? What length and diameter bolts/nuts should I use?
Alpine 7892
JBL 80.4 Amp
Type R 5.25 Comps
JBL 600/1 amp
JL 12" W6 V2
Usually I keep it to the length of the bolts to about the thickness of the material they are going through, sometimes a little shorter. The diameter of the bolts should be about the same diameter of the holes used to mount the subs. Notice how I use the word "about" a lot. This isn't a science(at least not this part); as long as air isn't able to get passed the bolts/tnuts, it works.
Bookmarks
