Results 1 to 11 of 11
Reload Thread: Air Space Exceeded
    U-H.Com's Avatar
    U-H.Com is offline Member
    Oct 2002
    Grimsby, Ontario
    38
    61
    Icon33 Air Space Exceeded
    Hey guys...
    Basically I was wondering what the drawbacks are of creating a sealed box with a larger internal volume than recommended....the recommended volume for my sub is 1.5-2.0 and right now my box is going to be 3.4 cubic feet. I was planning on using a different sub with this box, but changed my mind during box construction. Will it harm the sub at all?
    ss3079's Avatar
    ss3079 is offline Eh Dere Hi Dere Ho-ser
    Mar 2002
    Up North
    22,571
    What is the new sub you are going to be using in that box? Maybe it can handle the 3.4 cubes - 2 - 3.4 cubes is a pretty big difference. Also, how much power are you going to be sending the sub?
    Oh, hey, if you still building the box(which I doubt) change the dimensions
    - Steve
    Moderator
    2007 Chrysler 300C
    2005 Chevrolet Silverado 2500HD Crew Cab
    Optima, Volant, Bully Dog, Corsa, Gibson, Powermaster, California Super Trucks, Fox Racing, Airaid
    Alpine 7998, Alpine HDA-5460, Arc Audio MEQ-30, (2) Adire Audio Shiva, Image Dynamics CD-2COMP, Image Dynamics CX64, (2) Image Dynamics ID8V.2, Arc Audio 2100CXL, Arc Audio 4150CXL, Arc Audio 1500D-R
    2006 Kawasaki Ninja ZX14
    Quote Originally Posted by DJGTSR
    I dont mean to be rude, but what is the highest level of education that you finished?
    U-H.Com's Avatar
    Oct 2002
    Grimsby, Ontario
    38
    61
    My new sub is requiring 1.5-2.0. My original sub that I was building the box for was for the 3-3.5 range. And I can't really change the dimensions of the box, because its almost completed. I am just building a plexiglass window for it now...
    ss3079's Avatar
    Mar 2002
    Up North
    22,571
    What is the name of the sub? How much power?
    Moderator
    2007 Chrysler 300C
    U-H.Com's Avatar
    Oct 2002
    Grimsby, Ontario
    38
    61
    Its an MA Audio MA150XL...roughly 1500 watts going to it off a high current amp.
    ss3079's Avatar
    Mar 2002
    Up North
    22,571
    The box might be alright, try it out and see how it sounds. If it sounds like ****, time to build yourself a new box or redo your current box(which is easy)
    - Steve
    Moderator
    2007 Chrysler 300C
    U-H.Com's Avatar
    Oct 2002
    Grimsby, Ontario
    38
    61
    See I would be re-doing my box right now, although I have already attached two mirror pieces to the inside of it, and they are pretty securely on there. And they are the main dimensions of the box, so it would be hard to re-construct it....thanks for your help though
    ss3079's Avatar
    Mar 2002
    Up North
    22,571
    Oh ok, oh well, see how it sounds and then work from there
    - Steve
    Moderator
    2007 Chrysler 300C
  9. #9
    cromg454's Avatar
    cromg454 is offline Junior Member
    Jun 2002
    Houston
    I wouldn't recommend using that much power if the box is 1.4 cubes over what the sub was designed for, you going to possible end up with a lot of distortion and cook the sub at that power. What you can do is displace the air volume, use some scrap wood that you have left over from building the box, do the math on the wood you are putting into the box h x w x d and divide by 1728. Then simple glue it and screw it inside the box. Hope this has helped.
  10. #10
    Jearod's Avatar
    Jearod is offline Member
    Nov 2002
    Duncan, OK
    32
    33
    Sounds like a good opportunity to port your box now.
    Jearod
    http://members.sounddomain.com/Jearod
  11. #11
    Corsica's Avatar
    Corsica is offline CarAudio.com Veteran
    Jan 2002
    Ft Huachuca, AZ
    33
    3,997
    Well My MA XE is better in the 2.0 instead of their 1.5 they reccomend for ported. A co-workers 2 IL's are in a 5.3 instead of a 4.0 vented and they SLAM so try it man. Worst comes to worst u do it again.
    J
    "A man doesnt win a war by dying for his country. He does it by making the other poor dumb son of a beyotch die for his." Patton
    No system installed, but getting all the parts together.
    J
