Results 1 to 2 of 2
Reload Thread: L shaped Box
    snebweb512's Avatar
    snebweb512 is offline Junior Member
    Oct 2002
    Wi
    26
    L shaped Box
    hey ill be having a box built soon for 2 tempest 15s and i was wondering if this kinda box would work. My dimensions are 34W x 28D x 12H and then on the end towards the trunk it will have a 6H x 18W x 34 L addition so theres enough height to mount the subs. i figured out the 2 pieces seperatly and got 8.73 cubes. is this right or will it work and does it make sense. And does this sound like enough space for 2 tempests? thanks
    ramos's Avatar
    Dec 2001
    Virginia
    48
    10,311
    5 Post(s)
    Yes sir sounds like it will work as long as the two sections are sealed together well. And it should be enough room for two tempest.
    5 % equipment
    90 % install
    5% beer
