Results 1 to 2 of 2
Reload Thread: Need vinyl covering techniques/tips for box
    robbi's Avatar
    robbi is offline Junior Member
    Apr 2006
    colorado
    I have covered boxes with carpet before. How difficult are they to cover in vinyl? What should I be watching out for. I was just going to go and buy some vinyl and foam padding at the local fabric market and start glueing and stretching. How do you acclomplich the seems? I will be tackling this soon, so if you can help, please do!
    TypeRBass's Avatar
    TypeRBass is offline Walls are for wussies
    Apr 2005
    Tinley Park, IL
    34
    3,324
    Re: Need vinyl covering techniques/tips for box
    vinyl isn't easy to work with. and vinyl with padding under it on a box = :-\ everyone ive seen that has used the padding looks like crap. round all the corners on the outside of the box with a roundover bit on a router, use a rabbit bit on the sides of the box to tuck the vinyl in. get a HEAT gun to heat up the vinyl for the corners,
    spray glue, apply heat, STREEEETCH, push it in the divit you made with the rabbit bit, and throw some cold water on the vinyl to 'cool' it down. and repeat, not as easy as people make it seem.
    2005 MECA DB2 World Champion
    2006 MECA DB4 World Champion
    I smell a comeback...
  1. Where to find vinyl?
    By BulldogSr04 in forum Enclosure Design & Construction Help
    Last Post: 04-26-2004, 03:58 PM
  2. covering Fiberglass
    By PT Teal in forum Enclosure Design & Construction Help
    Last Post: 10-18-2003, 03:20 PM
  3. vinyl box covering
    By borbski in forum Enclosure Design & Construction Help
    Last Post: 08-01-2003, 01:18 PM
  4. got Vinyl?
    By Matador in forum General Discussion
    Last Post: 05-01-2003, 10:09 AM
  5. Vinyl for covering box and kickpanels?
    By RcRacerDrew in forum Subwoofers
    Last Post: 12-16-2002, 12:09 AM
